Error when buiding Petalinux with a Yocto layer
I'm trying to add the layer meta-oe to the petalinux. To this end, I've followed the instructions described here. But, when I build the project, I always receive the following message:
ERROR: ExpansionError during parsing /home/administrador/Documents/petaboots/oA_LISN4kv2_boot/components/ext_source/meta-openembedded/meta-oe/recipes-support/zile/zile_2.4.14.bb
Traceback (most recent call last):
  File "/opt/petalinux/components/yocto/source/arm/layers/core/meta/classes/base.bbclass", line 375, in __anon_656__opt_petalinux_components_yocto_source_arm_layers_core_meta_classes_base_bbclass(d=<bb.data_smart.DataSmart object at 0x7f5b658077f0>):
             pkgconfig = (d.getVar('PACKAGECONFIG', True) or "").split()
    >        pn = d.getVar("PN", True)
  File "/opt/petalinux/components/yocto/source/arm/layers/core/bitbake/lib/bb/data_smart.py", line 569, in DataSmart.getVar(var='PACKAGECONFIG', expand=True, noweakdefault=False, parsing=False):
         def getVar(self, var, expand, noweakdefault=False, parsing=False):
    >        return self.getVarFlag(var, "_content", expand, noweakdefault, parsing)
  File "/opt/petalinux/components/yocto/source/arm/layers/core/bitbake/lib/bb/data_smart.py", line 737, in DataSmart.getVarFlag(var='PACKAGECONFIG', flag='_content', expand=True, noweakdefault=False, parsing=False):
                     cachename = var + "[" + flag + "]"
    >            value = self.expand(value, cachename)
  File "/opt/petalinux/components/yocto/source/arm/layers/core/bitbake/lib/bb/data_smart.py", line 410, in DataSmart.expand(s=" ${@bb.utils.filter('DISTRO_FEATURES', 'acl', d)}", varname='PACKAGECONFIG'):
         def expand(self, s, varname = None):
    >        return self.expandWithRefs(s, varname).value
  File "/opt/petalinux/components/yocto/source/arm/layers/core/bitbake/lib/bb/data_smart.py", line 400, in DataSmart.expandWithRefs(s=" ${@bb.utils.filter('DISTRO_FEATURES', 'acl', d)}", varname='PACKAGECONFIG'):
                 except Exception as exc:
    >                raise ExpansionError(varname, s, exc) from exc
bb.data_smart.ExpansionError: Failure expanding variable PACKAGECONFIG, expression was  ${@bb.utils.filter('DISTRO_FEATURES', 'acl', d)} which triggered exception AttributeError: module 'bb.utils' has no attribute 'filter'
I've tried with other layers obtaining the same result, which means I'm skipping some step. Any clue?
Tags (3)
Re: Error when buiding Petalinux with a Yocto layer
Ok, I see what happens. The layer meta-openembedded have to match the version of poky used by Petalinux. In my case, I'm using Petalinux 2017.4, which uses the version 1.4.4. The correct branch of meta-openembedded is krogoth, that can be found here. However, Petalinux already stores the correct versions in /opt/petalinux/components/yocto/source/arm/layers/meta-oe, so it's not needed to add them from external sources.
