Error while building Linux image with PetaLinux
I'm trying to build a Linux image for Zynq with PetaLinux 2016.4 on Ubuntu 18.04, but PetaLinux fails after petalinux-build command, and it returns me an error related to libyaml and do_configure, in particular the following:
No real function for mknod: /home/gian/Documenti/HiPeRTLab/PetaLinux-workspace/ZynqLinux/build/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: undefined symbol: mknod
No real function for mknodat: /home/gian/Documenti/HiPeRTLab/PetaLinux-workspace/ZynqLinux/build/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: undefined symbol: mknodat
ERROR: libyaml-native-0.1.6-r0 do_configure: Function failed: do_configure (log file is located at /home/gian/Documenti/HiPeRTLab/PetaLinux-workspace/ZynqLinux/build/tmp/work/x86_64-linux/libyaml-native/0.1.6-r0/temp/log.do_configure.16068)
ERROR: Logfile of failure stored in: /home/gian/Documenti/HiPeRTLab/PetaLinux-workspace/ZynqLinux/build/tmp/work/x86_64-linux/libyaml-native/0.1.6-r0/temp/log.do_configure.16068
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function autotools_preconfigure
| DEBUG: Shell function autotools_preconfigure finished
| DEBUG: Executing python function autotools_copy_aclocals
| DEBUG: SITE files ['endian-little', 'common-linux', 'common-glibc', 'bit-64', 'x86_64-linux', 'common']
| DEBUG: Python function autotools_copy_aclocals finished
| DEBUG: Executing shell function do_configure
| Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/\${ <-- HERE ([^ \t=:+{}]+)}/ at /home/gian/Documenti/HiPeRTLab/PetaLinux-workspace/ZynqLinux/build/tmp/sysroots/x86_64-linux/usr/bin/automake line 3939.
| WARNING: exit code 255 from a shell command.
| ERROR: Function failed: do_configure (log file is located at /home/gian/Documenti/HiPeRTLab/PetaLinux-workspace/ZynqLinux/build/tmp/work/x86_64-linux/libyaml-native/0.1.6-r0/temp/log.do_configure.16068)
ERROR: Task 1464 (virtual:native:/storage/Programmi/PetaLinux/components/yocto/source/arm/layers/poky/meta/recipes-support/libyaml/libyaml_0.1.6.bb, do_configure) failed with exit code '1'
how can I solve this problem?
thanks
Re: Error while building Linux image with PetaLinux
According to page 8(Installation Requirements) in
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1144-petalinux-tools-reference-guide.pdf,
Ubuntu 18.04 is not supported OS
Newbie ansel
Bullshitttttttttttttttttt!
Visitor mansur
Did you find a solution to this problem other than installing Ubuntu 16.04
Mansur
Hi @ansel,
This is not something PetaLinux can support until open source Yocto supports https://www.xilinx.com/support/answers/71448.html
Sandeep
Visitor hristozov
I get a warning:
WARNING: Host distribution "Debian-9.11" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
and similar errors:
No real function for mknod: /home/stefan/workspaces/iot_comms_aes/iot_comms_aes/petaLinux/build/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: undefined symbol: mknod
No real function for mknodat: /home/stefan/workspaces/iot_comms_aes/iot_comms_aes/petaLinux/build/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: undefined symbol: mknodat
WARNING: petalinux-user-image-1.0-r0 do_rootfs: No not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: real not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: function not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: for not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: mknod: not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: /home/stefan/workspaces/iot_comms_aes/iot_comms_aes/petaLinux/build/tmp/sysroots/x86_64-linux/usr/bin/../lib/pseudo/lib64/libpseudo.so: not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: undefined not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: symbol: not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: mknod not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: mknodat: not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
WARNING: petalinux-user-image-1.0-r0 do_rootfs: mknodat not found in the base feeds (plnx_arm cortexa9t2hf-neon cortexa9t2hf-vfp cortexa9hf-neon cortexa9hf-vfp armv7at2hf-neon armv7ahf-neon armv7at2hf-vfp armv7ahf-vfp armv6thf-vfp armv6hf-vfp armv5tehf-vfp armv5ehf-vfp armv5thf-vfp armv5hf-vfp noarch any all).
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Unable to install packages. Command '/home/stefan/workspaces/iot_comms_aes/iot_comms_aes/petaLinux/build/tmp/sysroots/x86_64-linux/usr/bin/smart --log-level=warning --data-dir=/home/stefan/workspaces/iot_comms_aes/iot_comms_aes/petaLinux/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/petalinux-user-image/1.0-r0/rootfs/var/lib/smart install --attempt -y ' returned 1:
error: no package(s) given
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/stefan/workspaces/iot_comms_aes/iot_comms_aes/petaLinux/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/petalinux-user-image/1.0-r0/temp/log.do_rootfs.22196
ERROR: Task 9 (/home/stefan/workspaces/iot_comms_aes/iot_comms_aes/petaLinux/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb, do_rootfs) failed with exit code '1'
when I try to build petalinux 16.4 on debian 9.11. According to the yocto documentation debian 9.x is supported.
Is there a solution for this problem?
regards,
Stefan
Hello @hristozov,
Try installing the gawk package on your build system, if you have not done so.
The mawk package is not quite as polite.
Luck!
Kind Regards,
Peimann, S. M.
Toddlers are the Storm-Troopers of the Great God Entropy.
Physics: Not Just a Good Idea, It's THE LAW.
Hi @herogian ,
PetaLinux 2016.4 was initial release of petalinux with backend yocto which is based on Krogoth release(Yocto 2.1). So you need to refer for right yocto version docs.
Code Name
Yocto Project Version
Current Version
Poky Version
BitBake Version
Xilinx PetaLinux Release Version
Jethro
2
2.0.3
14
1.28
Krogoth
2.1
2.1.3
15
1.3
v2016.4
Morty
2.2
2.2.4
16
1.32
v2017.x
Pyro
2.3
2.3.4
17
1.34
Not Supported
Rocko
2.4
2.4.4
18
1.36
v2018.x
Sumo
2.5
2.5.2
19
1.38
Not Supported
Thud
2.6
2.6.0
20
1.4
v2019.x
PetaLinux doesn't support Debian distribution as it aligns with Vivado and XSDK supported Linux distribution.
Sandeep
Visitor hristozov
Hi @peimann ,
I have both:
* gawk version 1:4.1.4+dfsg-1
* mawk version 1.3.3-17+b3
Hello @hristozov,
Make sure the you use "gawk" when typing "awk".  You don't want "mawk".
I think that the command "awk --version" will show a GNU banner.  I believe that "mawk --version" simply simply complains "mawk: not an option: --version".
To deal with the problem in libyaml, you might try checking versions; I'm not sure what is going on there.  I think that the PetaLinux documentation identifies a specific, required version.
We have an updated Ubuntu that is also not tested, and it apparently works.  After fixing a couple simple things like "gawk".
If you can't solve that library problem directly, I suggest that you revert to a supported Linux and demonstrate correct function.  At least you will make forward progress on your project.  Also, you will have specific library versions identified based on your working environment, which can be then tested in your non-spec environment.  Since you are supporting a software version that is nearly three years out of date, this won't be an easy path.  Have you considered moving to 2019.1 or 2019.2?
Kind Regards,
Peimann, S. M.
