pulsar
Errors in petalinux-config command
Hello all
I tried to implement the "Steps to Import Hardware Configuration"
according page 21 of UG1144.
Initially I made the project from Digilent's file "Petalinux-Zybo-Z7-10-2017.4-1.bsp"
I did the following steps:
1) cd into /home/victor
2) source /opt/pkg/petalinux/settings.sh
3) copied file Petalinux-Zybo-Z7-10-2017.4-1.bsp into /home/victor/Zibo-Z7-10__BSP
4) cd Zibo-Z7-10__BSP
5) victor@victor-System-Product-Name:~/Zibo-Z7-10__BSP$ petalinux-create -t project -s /home/victor/Zibo-Z7-10__BSP/Petalinux-Zybo-Z7-10-2017.4-1.bsp
INFO: Create project:
INFO: Projects:
INFO: * Zybo-Z7-10
INFO: has been successfully installed to /home/victor/Zibo-Z7-10__BSP/
INFO: New project successfully created in /home/victor/Zibo-Z7-10__BSP/
Then I tried to Import Hardware Configuration from my own project based on Digilent's Zibo-Z7-10
1) copied the file system.hdf into /home/victor/ZYBO-Z7-10__v2
2) cd /home/victor/Zibo-Z7-10__BSP/Zybo-Z7-10
3) victor@victor-System-Product-Name:~/Zibo-Z7-10__BSP/Zybo-Z7-10$ petalinux-config --get-hw-description=/home/victor/ZYBO-Z7-10__v2
INFO: Getting hardware description...
[INFO] generating Kconfig for project
[INFO] menuconfig project
/home/victor/Zibo-Z7-10__BSP/Zybo-Z7-10/build/misc/config/Kconfig.syshw:30:warning: defaults for choice values not supported
/home/victor/Zibo-Z7-10__BSP/Zybo-Z7-10/build/misc/config/Kconfig:568:warning: config symbol defined without type
Your configuration changes were NOT saved.
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
~/Zibo-Z7-10__BSP/Zybo-Z7-10/build/misc/plnx-generated ~/Zibo-Z7-10__BSP/Zybo-Z7-10
[INFO] generating machine configuration
[INFO] generating bbappends for project . This may take time !
[INFO] generating u-boot configuration files
ERROR: [Common 17-55] 'get_property' expects at least one object.
ERROR: Failed to generate u-boot configuration files
webtalk failed:Invalid tool in the statistics file:petalinux-yocto!
webtalk failed:Failed to get PetaLinux usage statistics!
ERROR: Failed to config project.
ERROR: Get hw description Failed!.
Please answer on the following questions:
1) what I did wrongly ?
2) how to avoid the ERRORs in this step ?
Thank you,
Victor.
pulsar
your hdf file is probably wrong...
Did you make it with the same release as Petalinux? (it must be)
If that bsp was created with 2017.4 you have to use that... and you are probably using something else, aren't you?
I know, it's a real PITA... hopefully you can get the corresponding version
pulsar
