carl711
Ethernet error: PHY not found
I am working on a custom board, we have used KSZ9031 Gigabit Ethernet Transceiver.
When I boot the board in u-boot it says
(1) mdio_register: non unique device name 'eth0'
(2)No ethernet found
And in the Kernel it says fixed-link has invalid PHY ADDRESS.
This is my device-tree
&gem0 {
	status = "okay";
 	xlnx,has-mdio = <0x01>;
	phy-handle = <&phy0>;
	phy-mode = "rgmii-id";
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_gem0_default>;
	local-mac-address = [00 0a 35 00 02 92];
	fixed-link {
		speed = <100>;
		full-duplex;
	phy0: phy@0 {
		reg = <0x00>;
		device_type = "ethernet-phy";
		compatible = "micrel,ksz9031";
pinctrl_gem0_default: gem0-default {
		mux {
			function = "ethernet0";
			groups = "ethernet0_0_grp";
		conf {
			slew-rate = <SLEW_RATE_SLOW>;
			io-standard = <IO_STANDARD_LVCMOS33>;
		conf-rx {
			pins = "MIO32", "MIO33", "MIO34", "MIO35", "MIO36",
									"MIO37";
			bias-high-impedance;
			low-power-disable;
		conf-tx {
			pins = "MIO26", "MIO27", "MIO28", "MIO29", "MIO30",
									"MIO31";
			bias-disable;
			low-power-enable;
		mux-mdio {
			function = "mdio0";
			groups = "mdio0_0_grp";
		conf-mdio {
			bias-disable;
What could be the issue?
shabbirk
Hi @carl711
Can you try changing the phy node to remove device_type = "ethernet-phy"; compatible = "micrel,ksz9031"; and just keep the reg property something like this:
phy0: phy@0 {
		reg = <0x00>;
Best Regards
Shabbir
carl711
Thanks @shabbirk  for your reply.
I tried using your sugession, but didn't work for me.
And i would like to mention one more thing...
When my board boots , when it enters the u-boot stage I see this:
U-Boot 2019.01 (Jan 04 2020 - 18:23:12 +0530)
Board: Xilinx ZynqMP
DRAM:  1 GiB
EL Level:        EL2
Chip ID:        zu19eg
MMC:   sdhci@ff160000: 1, sdhci@ff170000: 0
Loading Environment from FAT... OK
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Net:   ZYNQ GEM: ff0b0000, phyaddr 0, interface rgmii-id
PHY is not detected
GEM PHY init failed
eth-1: ethernet@ff0b0000
Please note the line in bold.
And if I stop in u-boot and do mdio list, this is what I get:
ZynqMP> mdio list
eth0:
ZynqMP>
Why am I seeing "eth0:" instead of "eth1:" ??
As seen before in u-boot , the bolded line.
carl711
Hey @shabbirk  could you give your input on this.
