classic037
Ethernet ping test problems
Hi.
My Development Environment.
MicroZed(zynq7020)
MicroZed Embedded Vision Kits
Petalinux (Zynq7020 BSP)
I applied zynq7020 bsp and BOOT.bin, image.ub file sd card write so uart connect booting
PC(Windows7) Ip setting
IP:192.168.1.100
subnet:255.255.255.0
gateway:192.168.1.10
Microzed
IP:192.168.1.10
gateway:192.168.1.100
Ping test in  PC(windows7)->Microzed  is possible but Microzed -> PC(Window7) impossible
I refer to the documents below.
http://zedboard.org/sites/default/files/documentations/MicroZed_GettingStarted_v1_1.pdf
Please Requests for help.
thank you.
rfs613
Please check that Windows 7 firewall is configured to allow ICMP packets.
See for example https://technet.microsoft.com/en-us/library/cc738456%28v=ws.10%29.aspx
  • You can enable other computers to reach your computer with the ping command by selecting the Allow incoming echo request check box
