ritanagar
Ethernet support in Linux running on PPC405(virtex4-ML410)
How can we add ethernet support to my linux image running on Powerpc and trasfer files from Host to target?
Does adding Ethernet MAC ip add it, or we have to do certain changes in kernel ?????
linnj
You should review the ML405 h/w design which you can get from the wiki at http://xilinx.wikidot.com.
Yes to all your questions below, but you need to do your homework more.  There are reference designs (not for the ML410) already doing this.
ritanagar
thanks sir, dont worry I will do all homework as u said.I already added ethernet but I just need to confirm that I m going right or not.
