bartokon
FPGA Manager + Overlays. How to modify pl-custom.dtsi?
Hi!
I would like to intergrate PYNQ with custom axi-based IP-cores, that needs some modifications in system-user.dtsi
This is system-user.dtsi programmable logic references:
&ZmodADC_0_AXI_ZmodADC1410_1 {
	compatible = "generic-uio";
&ZmodDAC_0_AXI_ZmodDAC1411_v1_0_0 {
&amba_pl {
	axidma_chrdev_0: axidma_chrdev@0 {
		compatible = "xlnx,axidma-chrdev";
		dmas = <&ZmodADC_0_axi_dma_0 0>;
		dma-names = "rx_channel";
		index = <0>;
	axidma_chrdev_1: axidma_chrdev@1 {
		dmas = <&ZmodDAC_0_axi_dma_1 0>;
		dma-names = "tx_channel";
		index = <1>;
 This is pl.dtsi generated by petalinux 2020.1 (Without fpga manager)
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Sat Sep 19 17:22:26 2020
	amba_pl: amba_pl {
		#address-cells = <1>;
		#size-cells = <1>;
		compatible = "simple-bus";
		ranges ;
		ZmodADC_0_AXI_ZmodADC1410_1: AXI_ZmodADC1410@43c00000 {
			clock-names = "s00_axi_aclk";
			clocks = <&misc_clk_0>;
			compatible = "xlnx,AXI-ZmodADC1410-1.0";
			interrupt-names = "lIrqOut";
			interrupt-parent = <&intc>;
			interrupts = <0 29 4>;
			reg = <0x43c00000 0x10000>;
			xlnx,s00-axi-addr-width = <0x7>;
			xlnx,s00-axi-data-width = <0x20>;
		misc_clk_0: misc_clk_0 {
			#clock-cells = <0>;
			clock-frequency = <50000000>;
			compatible = "fixed-clock";
		ZmodADC_0_axi_dma_0: dma@40400000 {
			#dma-cells = <1>;
			clock-names = "s_axi_lite_aclk", "m_axi_s2mm_aclk";
			clocks = <&misc_clk_0>, <&misc_clk_1>;
			compatible = "xlnx,axi-dma-7.1", "xlnx,axi-dma-1.00.a";
			interrupt-names = "s2mm_introut";
			interrupts = <0 30 4>;
			reg = <0x40400000 0x10000>;
			xlnx,addrwidth = <0x20>;
			xlnx,sg-length-width = <0x10>;
			dma-channel@40400030 {
				compatible = "xlnx,axi-dma-s2mm-channel";
				dma-channels = <0x1>;
				xlnx,datawidth = <0x20>;
				xlnx,device-id = <0x0>;
		misc_clk_1: misc_clk_1 {
			#clock-cells = <0>;
			clock-frequency = <100000000>;
		ZmodDAC_0_AXI_ZmodDAC1411_v1_0_0: AXI_ZmodDAC1411_v1_0@43c10000 {
			compatible = "xlnx,AXI-ZmodDAC1411-v1-0-1.0";
			reg = <0x43c10000 0x10000>;
		ZmodDAC_0_axi_dma_1: dma@40410000 {
			#dma-cells = <1>;
			clock-names = "s_axi_lite_aclk", "m_axi_mm2s_aclk";
			interrupt-names = "mm2s_introut";
			interrupts = <0 31 4>;
			reg = <0x40410000 0x10000>;
			xlnx,sg-length-width = <0xe>;
			dma-channel@40410000 {
				compatible = "xlnx,axi-dma-mm2s-channel";
				xlnx,device-id = <0x1>;
Now I would like to enable the FPGA manager and still have pl.dtsi updated with changes.
I'm moving pl references from system-user.dtsi to pl-cutom.dtsi like this:
This is pl-custom.dtsi after enabling FPGA manager:
 * Version:
 * Today is: Sat Sep 19 18:38:42 2020
/dts-v1/;
/plugin/;
	fragment@0 {
		target = <&fpga_full>;
		overlay0: __overlay__ {
			#size-cells = <1>;
			firmware-name = ".bin";
	fragment@1 {
		target = <&amba>;
		overlay1: __overlay__ {
			afi0: afi0@f8008000 {
				#size-cells = <0>;
				compatible = "xlnx,afi-fpga";
				reg = <0xF8008000 0x1000>;
				xlnx,afi-width = <0>;
			clocking0: clocking0 {
				#clock-cells = <0>;
				assigned-clock-rates = <100000000>;
				assigned-clocks = <&clkc 15>;
				clock-output-names = "fabric_clk";
				compatible = "xlnx,fclk";
			clocking1: clocking1 {
				#clock-cells = <0>;
				assigned-clocks = <&clkc 16>;
	fragment@2 {
		target = <&amba>;
		overlay2: __overlay__ {
			#size-cells = <1>;
				#clock-cells = <0>;
				#dma-cells = <1>;
				#clock-cells = <0>;
				#dma-cells = <1>;
I have tried adding this to pl-custom.dtsi:
    &fragment@2 {
        &overlay2 {
			index = <0>;
			index = <1>;
Could someone give me a hand with this?
How should I modify pl-custom.dtsi?
bartokon
If anyone is interested I have used pl.dtsi generated by petalinux and use this: https://github.com/byuccl/PYNQ-PRIO to generate overlay.
stephenm
Normally, if you wanted to updated a DT node in Petalinux, you would update this node via the system-user.dtsi. for example:
@yournode{
   update here;
However, this will not work if the overlay is enabled as this node will not be found. In your case you will have to manually update the pl.dtsi
aravindb
HI @bartokon
Please  modify the pl device tree changes by adding into pl-custom.dtsi & we can see that is reflecting in final dtbo file.
you just need to add your changes in project-spec/meta-user/recipes-bsp/device-tree/files/pl-custom.dtsi file
FPGA Manager will take care of adding this pl-custom.dtsi changes to final dtbo file.
I just enabled this below configurations to enable the Device tree overlay.
Make sure to enable this blow configurations:
petalinux-config
FPGA Manager  --->
   [*] Fpga Manager
petlinux-conig -c kernel
                               Device Drivers  --->
                               *- Device Tree and Open Firmware support  --->
    [*]   Device Tree overlays
    [*]   Device Tree Overlay ConfigFS interface
You can see the same changes  are reflecting in dtbo file &  after converting it from  dtbo to dtsi  file using “dtc -I dtb -O dts base.dtbo -o system.dtsi” command
Note: you will not see any custom pl device tree changes added in pl.dtsi file after adding it to pl-custom.dtsi file & build it. you will only see those changes in dtbo file.
Thanks & regards
Aravind
bartokon
Petalinux is overriding pl.dtsi every time you modify it. You could do "chattr +i" to prevent modifications to this file, but this is not a solution but workaround.
bartokon
Yes, all these options are already activated. I'm not sure about: “dtc -I dtb -O dts base.dtbo -o system.dtsi”  because petalinux won't generate base.dtbo (or anything) if build fails!
I think the problem is with pl-custom.dtsi in meta-user, but I'm not sure how can I override properties of these fragments
Could you take a look at this bsp?
bartokon
stephenm
You can also use the DTC manually:
  • dtc -O dtb -o pl.dtbo -b 0 -@ pl.dtsi
You can get the DTC from git:
