FSBL, PMUFW & ARM Secure FW not building after upgrading Petalinux to 2018.2
Hi There !
I'm working on upgrading from Petalinux 2017.3 to 2018.2 and now everything builds just fine - Except for the FSBL, PMUFW & ARM Secure firmware (bl31.bin). No mentioning of either one of them in the entire build directory. In other words it does not even look like it attempts to build them. If I build manually with
petalinux -c fsbl
it compiles OK, but I'd rather have everything done in one swoop
Any thoughts on what this could be ?
Thanks in advance
/Otto
Re: FSBL, PMUFW & ARM Secure FW not building after upgrading Petalinux to 2018.2
Hi @ottob,
Can you provide the steps how did you migrated?
Did you upgrade your hdf to 2018.2?
Sandeep
Hi Sandeep !
Using a script I can toggle between 2017.3 and 2018.2, see below
Yes, I did load in the hdf file from 2018.2 Vivado using petalinux-configure --get-hw-description
#!/bin/bash
if [[ "$#" < "1" ]]; then
echo "Usage: set_petalinux_ver.sh [173 | 182] "
exit 1
fi
if [[ "$1" -eq "173" ]]; then
echo "Configuring for Petalinux 2017.3"
ln -sf u-boot-xlnx_%.bbappend_173 project-spec/meta-user/recipes-bsp/u-boot/u-boot-xlnx_%.bbappend
ln -sf linux-xlnx_%.bbappend_173 project-spec/meta-user/recipes-kernel/linux/linux-xlnx_%.bbappend
ln -sf system-user-17.3.dtsi project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
ln -sf petalinux-user-image.bbappend_173 project-spec/meta-user/recipes-core/images/petalinux-user-image.bbappend
exit 0
fi
if [[ "$1" -eq "182" ]]; then
echo "Configuring for Petalinux 2018.2"
ln -sf u-boot-xlnx_%.bbappend_182 project-spec/meta-user/recipes-bsp/u-boot/u-boot-xlnx_%.bbappend
ln -sf linux-xlnx_%.bbappend_182 project-spec/meta-user/recipes-kernel/linux/linux-xlnx_%.bbappend
ln -sf system-user-18.2.dtsi project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
ln -sf petalinux-user-image.bbappend_182 project-spec/meta-user/recipes-core/images/petalinux-user-image.bbappend
exit 0
fi
exit 1
Are you using same project switching between two versions?
Sandeep
Hi Sandeep !
Yes, its a clean checkout from svn with only the source files (no generated files committed) though
If I could just get the source code of petalinux-build it would be pretty easy to spot.. Anyway, I can live with it for now
/Otto
