Mentor
Mentor
FSBL and U-boot cannot find QSPI
When I create a new FSBL with SDK 2013.3 U-boot can no longer find the QSPI on the Zedboard:
SF: Unsupported manufacturer 00
*** Warning - spi_flash_probe() failed, using default environment
Is anyone experiencing the same? What is going on?
Maarten
Mentor
Mentor
Ah, thank you.
So one must enable Feedback Clk on MIO8.
But why was this not enabled by the zedboard template that I used?
You can check the discussion here:
http://forums.xilinx.com/xlnx/board/crawl_message?board.id=ELINUX&message.id=6686
Mentor
Mentor
Ah, thank you.
