eliezer
FTP Client in Petalinux
I am not trying to set up an FTP server on my board, I am trying to access an external FTP server from the command line on my board.
Unlike other Linux installations, it seems that my Petalinux build does not have access to the FTP command.
Is there something I can include in the rootfs configuration to enable this command?
Using Petalinux 2019.1.
eliezer
I found the answer. There is no "ftp" command for Petalinux, but "ftpget" from Busybox seems to handle the client-side needs for FTP.
shabbirk
Hi @eliezer
You will have to enable FTP support from busybox utils. Please refer to the below forum thread on the details:
https://forums.xilinx.com/t5/Embedded-Linux/ftp-not-working-in-2019-petalinux-pre-built-linux-on-Zynq-zc706/td-p/1031437
Let us know if still have any issues
Best Regards
Shabbir
eliezer
That thread appears to be about an FTP server, not a client. They reference using FTP "from their windows system".
Additionally, that thread doesn't have an answer for FTP, the poster gave up and used SFTP instead.
eliezer
rfs613
Another option is the busybox wget command (source code), which supports FTP, HTTP, and (if configured) HTTPS.
wget ftp://servername/path/to/file
