Newbie jaygummers
Facing No Valid Subsystem Error
I'm working on a project copied from others. The folder contains subfolders such as components, subsystem, hw-description and other files. But when I used the petalinux-build or petalinux-config, the error occurred with note "No valid subsystem is found" and "(my Petalinux tools installed dir)/components/ is invalid, it has space" (the latter will disappear after I used petalinux-config --searchpath --delete).  Maybe you can try to use the play ps4 games on pc using ps4 emulator. I also try to build an BSP with this folder but it will ignore the components folder within it so that I can only get a bsp without any components.
I'm very confused now since I'm not that familiar with Petalinux tools. What should I do to use this existing project?
Plz help me. Best regards!
Jay
Scholar xilinxacct
Re: Facing No Valid Subsystem Error
@jaygummers
Does this solution help?... https://forums.xilinx.com/t5/Embedded-Linux/No-valid-subsystem-is-found-ERROR/m-p/906354#M30003
Hope that helps.
If so, please mark as solution accepted. Kudos also welcomed. :-)
