Failed to Extract Yocto SDK. error
I am using Petalinux 2020.1 and read UG1144
i use petalinux-config command to config the project.
but after i exit the config menu,some error appera,which is as follows.
i find this question on xilinx form,but the best solvtion is to install petalinux 2019.1.
what should i do to fix this bug? should i install petalinux 2019.1?
my os is ubuntu 18.04.1,thank you for your reply!
petalinux-config --get-hw-description /home/ysy/project/linux-prj/
INFO: sourcing build tools
INFO: Getting hardware description...
INFO: Rename system_wrapper.xsa to system.xsa
[INFO] menuconfig project
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] extracting yocto SDK to components/yocto
ERROR: Failed to Extract Yocto SDK.
ERROR: Failed to config project.
ERROR: Get hw description Failed!.
