luffeyluo
Failed to build a petalinux project
when I'm using command:petalinux-build
to build a project,here is an error.
No driver for stdin peripheral psu_uart_0. Check the following reasons:
|  1. psu_uart_0 is not accessible from processor psu_pmu_0.
|  2. No Driver block is defined for psu_uart_0 in MSS file.
How to handle it, pls help.
longley
Hi, @luffeyluo, It looks like you don't have enable uart_0 in your design. Have you enabel UART_0 in your design? or do you enable uart_1? What's your petalinux version? What commands you've run or settings you've set before running petalinux-build? Could you share your HDF file?
Longley
Versal Blogs
luffeyluo
I solved it,when I recreate the hdf file ,it works. thanks
