Visitor kaito87
Failed to build custom application in petalinux 2017.4
I have created petalinux image based on UG1144 and next I want to run HEVC HM Test Model application on the ZC702 board. I followed the instruction s from the link above and the UG981 documentation, I use command petalinux-create -t apps --name myapp --enable to create myapp folder for HM Test Model application (the application can be downloaded in here) and the folder automatically created on /project-spec/meta-user/recipes-apps/myapp/. And then from README file in the myapp folder that I read on the folder You can easily import any exiting application code by copying it into this directory, and editing the automatically generated Makefile. Then I copied the folder HEVC HM Test Model application to the myapp folder. In the myapp folder there is a bitbake file. Then I edit the bitbake file become like this.
# This file is the myapp recipe.
SUMMARY = "hevc application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file:///trunk/*.cpp \
           file:///trunk/*.h \
           file:///trunk/build/linux/makefile \
S = "${WORKDIR}"
do_compile() {
	     oe_runmake
do_install() {
	     install -d ${D}${bindir}
	     install -m 0755 myapp ${D}${bindir}
After that I run petalinux-config -c rootfs and petalinux-build
I got this error
b304@b304-pc:~/Documents/tes1/project-spec/meta-user/recipes-apps/myapp$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Loading cache: 100% |#####################################################################################################################################| Time: 0:00:00
Loaded 3256 entries from dependency cache.
Parsing recipes: 100% |###################################################################################################################################| Time: 0:00:01
Parsing of 2465 .bb files complete (2432 cached, 33 parsed). 3258 targets, 226 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |################################################################################################################################| Time: 0:00:03
Checking sstate mirror object availability: 100% |########################################################################################################| Time: 0:00:06
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: myapp-1.0-r0 do_fetch: Failed to fetch URL file:///trunk/build/linux/makefile, attempting MIRRORS if available
ERROR: myapp-1.0-r0 do_fetch: Fetcher failure: Unable to find file file:///trunk/build/linux/makefile anywhere. The paths that were searched were:
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp-1.0/petalinux
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp/petalinux
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/files/petalinux
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp-1.0/plnx_arm
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp/plnx_arm
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/files/plnx_arm
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp-1.0/armv7a
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp/armv7a
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/files/armv7a
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp-1.0/zynq
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp/zynq
    /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/files/zynq
    /home/b304/Documents/tes1/build/downloads
ERROR: myapp-1.0-r0 do_fetch: Fetcher failure for URL: 'file:///trunk/build/linux/makefile'. Unable to fetch URL from any source.
ERROR: myapp-1.0-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/b304/Documents/tes1/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/myapp/1.0-r0/temp/log.do_fetch.4295
ERROR: Task (/home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2431 tasks of which 2430 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
The HEVC HM Test Model application folder has many sub folders as shown below
I need help to solve this error, Thanks in advance
Re: Failed to build custom application in petalinux 2017.4
Hi @kaito87,
You need to fix the SRC_URI  in your recipe
LICENSE = "MIT"
SRC_URI = "file://trunk/*.cpp \
           file://trunk/*.h \
           file://trunk/build/linux/makefile \
S = "${WORKDIR}"
do_compile() {
	     oe_runmake
do_install() {
Sandeep
Visitor kaito87
Hi @sandeepg thanks for reply, I tried what you suggested but, I still got error like this even I change the SRC_URI
[INFO] building myapp
INFO: bitbake myapp
Loaded 3258 entries from dependency cache.
WARNING: /home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/myapp.bb: Unable to get checksum for myapp SRC_URI entry makefile: file could not be found--
Parsing of 2467 .bb files complete (2434 cached, 33 parsed). 3260 targets, 226 skipped, 0 masked, 0 errors.
Initialising tasks: 100% |################################################################################################################################| Time: 0:00:00
Checking sstate mirror object availability: 100% |########################################################################################################| Time: 0:00:01
WARNING: myapp-1.0-r0 do_fetch: Failed to fetch URL file://trunk/build/linux/makefile, attempting MIRRORS if available
ERROR: myapp-1.0-r0 do_fetch: Fetcher failure: Unable to find file file://trunk/build/linux/makefile anywhere. The paths that were searched were:
ERROR: myapp-1.0-r0 do_fetch: Fetcher failure for URL: 'file://trunk/build/linux/makefile'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/b304/Documents/tes1/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/myapp/1.0-r0/temp/log.do_fetch.11184
NOTE: Tasks Summary: Attempted 554 tasks of which 553 didn't need to be rerun and 1 failed.
Summary: There were 2 WARNING messages shown.
ERROR: Failed to build myapp
webtalk failed:PetaLinux statistics:extra lines detected:notsent_nofile!
webtalk failed:Failed to get PetaLinux usage statistics!
And then I change the SRC_URI and run petalinux-build again
LICENSE = "MIT"
SRC_URI = "file://home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/trunk/*.cpp \
           file://home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/trunk/*.h \
           file://home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/trunk/build/linux/makefile \
S = "${WORKDIR}"
do_compile() {
	     oe_runmake
do_install() {
Got another error
INFO: bitbake myapp
WARNING: myapp-1.0-r0 do_fetch: Failed to fetch URL file://home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/trunk/build/linux/makefile, attempting MIRRORS if available
ERROR: myapp-1.0-r0 do_fetch: Fetcher failure: Unable to find file file://home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/trunk/build/linux/makefile anywhere. The paths that were searched were:
ERROR: myapp-1.0-r0 do_fetch: Fetcher failure for URL: 'file://home/b304/Documents/tes1/project-spec/meta-user/recipes-apps/myapp/trunk/build/linux/makefile'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/b304/Documents/tes1/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/myapp/1.0-r0/temp/log.do_fetch.12669
Should I do cross compile for all of "cpp","h",and "makefile"?
