Observer jchou.1992
Failed to build ug1209 design2 image.
Hello:
I use Petalinux v2018.2 to build ug1209 design2 application for zcu102 board.
Due to I no  <petalinux_project>/project-spec/meta-user/recipes-dt/device-tree/files/system-top.dts in the linux project,
I use  <petalinux_project>/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi to add following settings to enable DRM driver:
&xlnx_dp {
phy-names = "dp-phy0", "dp-phy1";
phys = <&lane1 5 0 3 27000000>, <&lane0 5 1 3 27000000>;
status = "okay";
After all settings, I build the image. then error message appear:
Error: /home/eyem5/user/xilinx-zcu102-2018.3/build/tmp/work/zcu102_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+f38738e568-r0/system-user.dtsi:4.1-9 Label or path xlnx_dp not found
How can I fix the error?
Jimmy
Re: Failed to build ug1209 design2 image.
Hi @jchou.1992,
I don't think this will hang the boot process.
Best Regards
Kranthi
Hi @jchou.1992,
Could you please refer to below document which is latest one.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1209-embedded-design-tutorial.pdf
Best Regards
Kranthi
Observer jchou.1992
Hi Kranthi:
Build image successfully! but appears :
WARNING: petalinux-user-image-1.0-r0 do_rootfs: [log_check] petalinux-user-image: found 1 warning message in the logfile: [log_check] warning: %post(sysvinit-inittab-2.88dsf-r10.zcu102_zynqmp) scriptlet failed, exit status 1.
Does this warning make any trouble?
Jimmy
Hi @jchou.1992,
Best Regards
Kranthi
Observer jchou.1992
Hello Kranthi:
After SD boot,  I login root in terminal,  following ug1209 2018.2 version. I key in:
# export DISPLAY=:0.0
# /usr/bin/Xorg -depth 16&
# tricube
No video output.
Error message: -sh Xorg: command  not found.
What wrong with me?
Jimmy
