Failed to generate BIF file, file ../images/linux/*.bit doesn't exist
I am trying to build SD image with own PL HDF file, but I can;t manage to package it.
I followed to flow in the petalinux user guide (ug1144-petalinux-tools-reference-guide.pdf -> Generate Boot Image)
the Flow i did:
- I created a project using
  • petalinux-create -t project -s ../debug_board_config/xilinx-ultra96-reva-v2018.3-final.bsp
- then I used my hdf file (debug_board_config == hdf folder)
  • petalinux-config --get-hw-description ../../../debug_board_config
 - I fixed the workaround of the axi_uart16550_0 problem as described in https://github.com/Avnet/Ultra96-PYNQ
  • vi project-spec/meta-user/conf/petalinuxbsp.conf  => add line at the end of file:
    MACHINE_FEATURES_remove_ultra96-zynqmp = "mipi"
- build image
  • petalinux-build
- packaing to BIN format
  • petalinux-package --boot --format BIN --fsbl images/linux/zynqmp_fsbl.elf --u-boot images/linux/u-boot.elf --pmufw images/linux/pmufw.elf --fpga images/linux/*.bit --force
==> then i get an error of "Failed to generate BIF file, file ../images/linux/*.bit doesn't exist"
where from and how should i create the .bit file?
Re: Failed to generate BIF file, file ../images/linux/*.bit doesn't exist
Your bitstream should be part of your hdf. When you exported your hdf (from vivado), did you include bitstream in it before using it to build your petalinux project?
