Observer welcomelm
Failed to install 2018.3 in ubuntu 16.04
I already installed the required packages as asked by installation guide
sudo apt-get install -y gcc git make net-tools libncurses5-dev tftpd zlib1g-dev libssl-dev flex bison libselinux1 gnupg wget diffstat chrpath socat xterm autoconf libtool tar unzip texinfo zlib1g-dev gcc-multilib build-essential libsdl1.2-dev libglib2.0-dev zlib1g:i386 screen pax gzip
min@minli-office:~/work/petalinux$ ~/Downloads/petalinux-v2018.3-final-installer.run
INFO: Checking installation environment requirements...
awk: read error (Bad address)
Please refer to the PetaLinux Tools Installation Guide.
Check the troubleshooting guide at the end of that manual, and if you are
unable to resolve the issue please contact customer support with file:
/home/min/work/petalinux/petalinux_installation_log
/home/min/Downloads/petalinux-v2018.3-final-installer.run: line 139: /tmp/tmp.JuexV8XQco/: Is a directory
ERROR: Failed to extract Petalinux installer...
Re: Failed to install 2018.3 in ubuntu 16.04
Try installing  gawk in ubuntu and check if that resolves the error
Please refer to this forum link on installing petalinux
https://forums.xilinx.com/t5/Embedded-Linux/petalinux-2018-3-installation-on-ubuntu-16-04-03/m-p/931658#M31344
Best Regards
Shabbir
