Failed to run SDSoC application on linux
Hi all,
I have created a Linux application on SDSoC using the Matrix-multiplication template, all build process was successful but when testing on the board i get the following error:
ubuntu@arm:~$ ./my_app.elf
ERROR: /dev/mem can't be opened
Failed to map accelerator device @83c00000. Aborting
ERROR: Counter physical addresses not mapped yet!
but when run it with root access the board is no longer responding
ubuntu@arm:~$ sudo su
root@arm:/home/ubuntu# ./my_app.elf  ... i get no response, then i turn off the board
Note:
- I have included APF drivers : Device Drivers → Staging drivers → Xilinx APF Accelerator driver (ON)
- I have included APF DMA driver:: Device Drivers → Staging drivers → Xilinx APF Accelerator driver → Xilinx APF DMA engines support (ON)
- /dev/xlnk exists
ubuntu@arm:~$ dmesg | grep 'xlnk'
[ 1.861668] xlnk xlnk: Major 242
[ 1.863674] xlnk xlnk: xlnk driver loaded
[ 1.866297] xlnk xlnk: xlnk_pdev is not null
ubuntu@arm:~$
- I have tested a hello_world application (without hw acceleration), it worked fine.
ubuntu@arm:~$ sudo ./helloworld.elf
Hello world !
Please i need help to know if it misses some step to run my application.
Re: Failed to run SDSoC application on linux
Based  on Error log:
Looks like issue is in the Driver file , it not supporting to open device node file of "/dev/mem" by default
check the driver commo templete for open device node files
Thanks & Regards
Satish G
G Satish Kumar
Hi @gsatish10, thanks for your help,
I did as you indicated, i noticed that there are some differences in driver files comparing with driver files of linux-xlnx kernel, so i have replaced them with driver files found on linux-xlnx. then i have made another array partition SDSoC application. but the problem isn't solved
linaro@linaro-ubuntu-desktop:~$ ./my_tmp_app.elf
ERROR: unable to open xlnk
is there some other workaround to solve this problem ?
thanks
i have generated an SDSoC application using official xilinx linux kernel and it worked fine, so i'm thinking about two ways :
- Is there some branch in the ADI linux kernel that is close to the official xilinx one so that i can use to create my SDSoC application ?
- Is there a method to include ad9361 linux driver in Xilinx official kernel ?
Participant tianfangk
回复: Failed to run SDSoC application on linux
Did you solve the problem? I have a same problem with my xc7z010 platform. Could you give me some ideas to solve this problem? Thanks for your help.
Scholar watari
Hi @gsatish10
Would you use strace command to debug your application ?
Best regards,
Yes, I use strace to trace application
Satish G
G Satish Kumar
