Failed to start Load Kernel Modules in a Yocto Linux Image
Hi everyone,
I created a linux image from yocto, and I am with some issues in the Linux startup. (I can startup, but some kernel modules failed to be loaded)
My sd card has two partitions (boot + root):
The boot partition has: boot.bin, Image, system.dtb e o uEnv.txt (from Xilinx pre-Realeses)
The root partition has: the filesystem (FS) generated in yocto.
In the boot process the linux failed to load some kernel modules. I think the problem is somewhere in my FS, because using the FS of the Xilinx, I had no problems.
Here is part of the boot log.
Welcome to OpenEmbedded nodistro.0!
[    5.109485] systemd[1]: Set hostname to <zcu104-zynqmp>.
[    5.134181] systemd[1]: Initializing machine ID from random generator.
[    5.199572] [drm] Cannot find any crtc or sizes
[    5.364946] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgr.
[    5.382019] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    5.676183] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    5.691729] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    5.715820] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    5.733216] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on Journal Socket.
         Mounting Huge Pages File System...
         Mounting Kernel Debug File System...
         Mounting POSIX Message Queue File System...
         Starting Journal Service...
         Starting Remount Root and Kernel File Systems...
[    5.941737] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
         Starting Load Kernel Modules...
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Swap.
         Mounting Temporary Directory (/tmp)...
         Starting udev Coldplug all Devices...
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Mounted Temporary Directory (/tmp).
         Mounting Kernel Configuration File System...
         Mounting NFSD configuration filesystem...
         Starting Apply Kernel Variables...
         Starting Rebuild Hardware Database...
         Starting Create System Users...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Mounted Kernel Configuration File System.
[FAILED] Failed to mount NFSD configuration filesystem.
See 'systemctl status proc-fs-nfsd.mount' for details.
[DEPEND] Dependency failed for NFS server and services.
[DEPEND] Dependency failed for NFS Mount Daemon.
[  OK  ] Started Apply Kernel Variables.
[    6.289079] systemd-journald[1701]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
[  OK  ] Reached target Containers.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Rebuild Journal Catalog...
         Starting Rebuild Dynamic Linker Cache...
         Starting Create Volatile Files and Directories...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Rebuild Journal Catalog.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
         Starting Run pending postinsts...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Rebuild Hardware Database.
         Starting udev Kernel Device Manager...
[  OK  ] Started Run pending postinsts.
[  OK  ] Started udev Kernel Device Manager.
         Starting Network Service...
[  OK  ] Found device /dev/ttyPS0.
[  OK  ] Started Network Service.
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting Network Name Resolution...
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target Network.
[  OK  ] Started Rebuild Dynamic Linker Cache.
         Starting Update is Completed...
[  OK  ] Started Update is Completed.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting sshd.socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on GPS (Global Positioning System) Daemon Sockets.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on sshd.socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Telephony service...
[  OK  ] Started Serial Getty on ttyS0.
         Starting RPC Bind Service...
[  OK  ] Started Kernel Logging Service.
         Starting Network Time Service (one-shot ntpdate mode)...
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Getty on tty1.
[  OK  ] Started System Logging Service.
[  OK  ] Started Xinetd A Powerful Replacement For Inetd.
[  OK  ] Started Serial Getty on ttyPS0.
[  OK  ] Reached target Login Prompts.
         Starting Login Service...
         Starting Save/Restore Sound Card State...
[  OK  ] Started RPC Bind Service.
[  OK  ] Started Network Time Service (one-shot ntpdate mode).
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Reached target Sound Card.
         Starting Network Time Service...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
[  OK  ] Started Login Service.
[  OK  ] Started Network Time Service.
[  OK  ] Started Telephony service.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Reached target Multi-User System.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
OpenEmbedded nodistro.0 zcu104-zynqmp ttyPS0
Does someone have any idea how can I resolve this?
Best regards
Re: Failed to start Load Kernel Modules in a Yocto Linux Image
Hi @a75445,
Please provide
Cheers,
Trigger
Hi @trigger ,
Thanks for the reply.
root@zcu104-zynqmp:~# systemctl status systemd-modules-load.service
��● systemd-modules-load.service - Load Kernel Modules
   Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sat 2020-01-25 04:48:55 UTC; 20s ago
     Docs: man:systemd-modules-load.service(8)
           man:modules-load.d(5)
  Process: 3020 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 3020 (code=exited, status=1/FAILURE)
Jan 25 04:48:55 zcu104-zynqmp systemd[1]: Starting Load Kernel Modules...
Jan 25 04:48:55 zcu104-zynqmp systemd-modules-load[3020]: Failed to find module 'fuse'
Jan 25 04:48:55 zcu104-zynqmp systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Jan 25 04:48:55 zcu104-zynqmp systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Jan 25 04:48:55 zcu104-zynqmp systemd[1]: Failed to start Load Kernel Modules.
Cheers
Hi @a75445
As you are working with Yocto : http://git.yoctoproject.org/cgit.cgi/poky/plain/meta/recipes-kernel/fuse/fuse_2.7.2.bb?h=laverne
IMAGE_INSTALL += " fuse "
inside recipe image or conf/local.conf
Cheers,
Trigger
Hi @trigger,
Thanks one more time for the reply,
I am not using the yocto from its git repository, I am using the oe-gnss-sdr-manifest, which uses fuse_2.9.8.
I wasn't able to find the fuse folder in the recipes-kernel, however, I found it in meta-oe/meta-filesystems/recipes-support.
I will try your suggestion.
If that resolves my problem I will mark your reply as solution.
Cheers
Hi @trigger,
I have tried what you suggested and didn't resolve my problem.
First I used IMAGE_INSTALL += " fuse " and my Linux stops booting (kernel panic)
After that occurred I checked the yocto documentation and it says the following:
  • Using IMAGE_INSTALL with the += operator from the /conf/local.conf file or from within an image recipe is not recommended as it can cause ordering issues.
  • When you use this variable, it is best to use it as follows:
    • IMAGE_INSTALL_append = " package-name"
So I tried IMAGE_INSTALL_append = " fuse" and I got the same problem.
 Any more suggestions?
Cheers.
Hi @a75445
Could you provide us error log ?
Cheers,
Trigger
Maybe enable CONFIG_FUSE_FS in kernel configuration
Hi @trigger ,
The log file is the same as my first post.
I can be wrong, but I think that the kernel is not the problem, because I am using the kernel provided by Xilinx Linux releases.
What I have, to be more clear, is:
  • A boot partition with: BOOT.BIN + uEnv.txt, Image and zynqmp-zcu104-revC.dtb [All from 2019.2-zcu104-release]
  • A root partition with: the filesystem generated by yocto.
I think the problem is in the filesystem because when I use the filesystem from 2019.2-zcu104-release all goes right and when I use my filesystem the problems that I aforementioned happen.
Cheers and thank you for the replay
@a75445
I don't have any idea :S
You can maybe take a look inside your rootfs and double check that driver is correctly deploy ? And try to built-in inside the kernel itself.
Cheer,
Trigger
