Observer esraaltun
Failed to start raise network interface on custom board
I work with custom board (zynq-7035) and use petalinux 2018.3 version. My custom board's ethernet chip is atheros-ar8035. So I used this link for enabling some kernel configuration.( https://forums.xilinx.com/t5/Embedded-Linux/Adding-Qualcomm-Atheros-ath10-support-to-petalinux/td-p/922086)
system-user.dtsi
/include/ "system-conf.dtsi"
&gem{
compatible = "cdns,zynq-gem", "cdns,gem";
reg = <0xe000b000 0x1000>;
status = "okay";
interrupts = <0 22 4>;
clocks = <&clkc 30>, <&clkc 30>, <&clkc 13>;
clock-names = "pclk", "hclk", "tx_clk";
#address-cells = <1>;
#size-cells = <0>;
phy-mode = "rgmii-id";
phy-handle = <&phy0>;
phy@0 {
compatible = "atheros,ar8035";
device_type = "ethernet-phy";
reg = <0x0>;
linux,phandle = <0x4>;
phandle = <0x4>;
It failed. How can I fix it?
Esra.
Observer esraaltun
Re: Failed to start raise network interface on custom board
I solved this problem.
petalinux-config -c kernel
Device Drivers -> Network device support -> Ethernet driver support→PHY device support and infrastructure→ at803x(atheros qualcom)
And I delete node that added in system-user.dtsi. It fixed, when I enabled at803x option.
Observer esraaltun
