omkar@apra.in
Fetch Interrupt from TSC2007 into linux running on MYD-C7Z020 board
I am using MYD-C7Z020 development board with MYC-C7Z020 CPU Module for Xilinx XC7Z020-1CLG400C.
Also I have 7" resistive touchscreen display (provided by MYiR) which is also connected to the board.
I am trying to figure out how to get interrupt in linux from a TSC2007 chip which is embedded into the board.
Following is the block I was able to find out from zynq-myd.dts file, which needs to be added in devicetree,
tsc2007@49 {
compatible = "tsc2007";
reg = <0x49>;
ti,x-plate-ohms = <655>;
ti,poll-period = /bits/ 64 <30>; //in ms
gpios = <&gpio0 117 1>; // 1 means active low
But I am not sure if the above configuration is proper or not.
Could you provide us some pointers on what configurations/changes we need to setup, to get interrupt from TSC2007 chip to linux.
For reference, please checkout the schematics of TSC2007 connections attached with this post.
gudishak
Hi omkar@apra.in,
You could try adding your slave details as mentioned below,
Zynq-7020 has two I2C switches where slaves are connected. you need to initalize them first then your slave.
Inside your switch you need to mention the i2c slaves like i2c@0, i2c@2.
i2c@e0004000 {
compatible = "cdns,i2c-r1p10";
status = "okay";
clocks = <0x1 0x26>;
interrupt-parent = <0x3>;
interrupts = <0x0 0x19 0x4>;
reg = <0xe0004000 0x1000>;
#address-cells = <0x1>;
#size-cells = <0x0>;
clock-frequency = <0x186a0>;
i2cswitch@74 {
compatible = "nxp,pca9548";
reg = <0x74>;
i2c@0 {
reg = <0x0>;
clock-generator@5d {
#clock-cells = <0x0>;
compatible = "silabs,si570";
temperature-stability = <0x32>;
reg = <0x5d>;
factory-fout = <0x9502f90>;
clock-frequency = <0x8d9ee20>;
i2c@2 {
reg = <0x2>;
eeprom@54 {
compatible = "at,24c08";
reg = <0x54>;
Check your design for your i2c bus where touch screen is connected. You can try adding the slave node repspectively.
Kranthi
Best Regards
Kranthi
