senkoo
File does exist but isnt seen in kernel
My name is Senna. I am working on a project with ZC702 dev kit.
I'm having issues with my program i want to run on my board. It is called ets-prg.elf and it is there but it can't be executed?
I'm not a linux master-mind :p. I looked on the internet and they said something about i32-libs but i did not see that in the petalinux rootfs configuration?
I included a screenshot of the problem.
Thanks in advance :)
Greetings,
Senna
watari
Hi @senkoo
Would you show me the result of following command ?
$ ls -lA /usr/bin/ets-prg.elf
$ file /usr/bin/ets-prg.elf
$ df -k -T
Best regards,
senkoo
Hello @watari,
Thank you very much for your reply. Here are the results from the commands:
root@ets-prg:/usr/bin# ls -lA /usr/bin/ets-prg.elf
-rwxr-xr-x    1 root     root         68928 Oct  4 07:41 /usr/bin/ets-prg.elf
root@ets-prg:/usr/bin# file /usr/bin/ets-prg.elf
-sh: file: not found
root@ets-prg:/usr/bin# df -k -T
Filesystem           Type       1K-blocks      Used Available Use% Mounted on
devtmpfs             devtmpfs          64         4        60   6% /dev
tmpfs                tmpfs         515652        68    515584   0% /run
tmpfs                tmpfs         515652        32    515620   0% /var/volatile
tmpfs                tmpfs             64         4        60   6% /dev
/dev/mmcblk0         vfat        15377744      2360  15375384   0% /run/media/mmcblk0
/dev/mmcblk0         vfat        15377744      2360  15375384   0% /mnt/mmc
watari
Hi @senkoo
I confirmed your answer.
At least, your environment (rootfs) is wrong.
Where do you put ets-prg.elf ?
I suggest to make sure rootfs first.
Best regards,
senkoo
Hello @watari,
I made an app with petalinux-create -t app etc for the ets-prg
in the files directory i put ets-prg.elf and in the ets-prg.bb file i say that that file needs to be installed.
Is that what you mean?
Greetings,
Senna
