First Password Attempt Fails
I'm running 2019.1. No issues at the UART console but if I try to login via SSH (ssh root@<my-ip-address>) the first attempt always fails. I have a few scripts to copy files and they now fail.
I'm using Dropbear.
Kenny
chen8494
Hi kenny
I have the same problem with you ,running 2019.1, and my ftp software filezilla can't access ftp&sftp.
I have a ZCU102 board ,so i try  with xilinx offer “ZCU102 BSP ”. It also have the same problem .
Do you solve the problem ? Do you know how to make  petalinux 2019.1 ftp&sftp work?
thanks
chen8494
I find two ways to solve this problem
1. https://forums.xilinx.com/t5/Embedded-Linux/dropbear-root-login-petalinux-2019-1/m-p/979852?search-action-id=137358904284&search-result-uid=979852
2.after boot  run script (uart)
#!/bin/bash
PID=$(ps -e|grep dropbear | grep -v grep|awk '{print $1}')
kill ${PID}
/usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
#!/bin/bash
kill ${PID}
abouassi
I have reported the issue internally to our development team.
Thanks for pointing this out.
Best regards,
Abdallah
larshb
Any updates?
Issue tracker?
The same problem does not apply to Telnet, btw.
larshb
chen8494
Petalinux (at least the one I'm using) is bundled with BusyBox v1.29.2 and there is no flag "-e" for ps (only "w" and "l").
