Re: GMII2RGMII Ethernet gem1 with Kernel 4.19 not working with Zynq7000
I am using Vivado 2019.1 and petalinux 2019.1 and finally it works. However, I do have to go to download the uboot-xlnx from the master branch to replace and use that in order to get things to work.
CK
Visitor csporer
Hello everybody,
after debugging in the kernel drivers I found the setting that the gem is working!
It was the devicetree setting...
Now it looks like this and works:
&gem1 {
  status = "okay";
    /*first emio gpio as reset*/
    reset-gpios = <&gpio0 54 1>;
    phyremote: ethernet-phy@2 {
        phy-mode = "rgmii-id";
        reg = <2>;
    gmiitorgmii: gmiitorgmii@31 {
        compatible = "xlnx,gmii-to-rgmii-1.0";
        reg = <31>;
        phy-handle = <&phyremote>;
Hope that helps someone else and I will close the ticket!
Thanks for the help!
