jackfrye11
GNU Make inside of Yocto PetaLinux
I have a petalinux app that looks like this
recipes-apps/<app>/files/<main_files>/a/<other_files>
I am trying to build the other_files with the main_files.
In recipes-apps/<app>/<app>.bb under SRC_URI, I have
SRC_URI =  "file://main_file.cpp \
                      file://a/subfile.h \
                      file://a/subfile.cpp \
By this time the Makefile gets hit to build these, will they all be in the same directory in Bitbake build environment or do I need to set up variables to include files from the parent and child directories for each other to build?
sandeepg
Hi John,
You need to add something like this.
# tins contains directories and sub-directories
SRC_URI += "file://tins \ " S = "${WORKDIR}" do_install() { install -d -m 0655 ${D}${includedir}/tins install -d -m 0655 ${D}${includedir}/tins/abc install -d -m 0655 ${D}${includedir}/tins/xyz install -m 0644 ${S}/tins/*.* ${D}${includedir}/tins/ install -m 0644 ${S}/tins/abc/*.* ${D}${includedir}/tins/abc/ install -m 0644 ${S}/tins/xyz/*.* ${D}${includedir}/tins/xyz/ } FILES_${PN} = "${includedir}/*"
Sandeep
jackfrye11
I was eventually able to get it to work. Had to include all paths with .h in the Makefile in all build recipes with -I and all full paths from the <app>/files/ folder to each source file in the SRC_URI
