s3s_elec
General usage of udmabuf
Using the Zynq(Z-7045) board and Petalinux 2016.2,
I'm creating a process to do DMA from PS to PL using udmabuf.
I'm sorry for the simple question...
Is memcpy() the fastest way to move data between source data address and udmabuf (CMA) address obtained by mmap()?
If there is a better way, please let me know.
After that I use CDMA with a setting that uses the CMA region as the source address and PL DDR as the destination address.
Thank you.
As far as I remember having the same question the fastest was posix write(..) directly  to the opw  /dev/udmabuf device file descriptor
But there was not much difference to mmap+memcpy
Next fastest was 4byte ptr access
s3s_elec
Hi juergen.kratochwill@grapho-metronic.com ,
Thank you for the useful information.
I try write() and compare it to mmap+memcpy() and choose the faster one.
Thanks!
did you find a significan difference?
s3s_elec
Hi juergen.kratochwill@grapho-metronic.com,
I'm sorry, I didn't report the results.
In my process, there didn't seem to be any big difference between the two.
I'm probably having a problem with my system, but I'm using write() because memcpy() sometimes causes my process to hang.
Thank you.
