Visitor tushar@raj
Getting error in setting up NFS
Sent: Wednesday, June 6, 2018 5:45 AM
Subject: RE: [External] RE: Getting error in setting up NFS
Hi Christophe,
I have added replies.
Tushar
Sent: 05 June 2018 07:49 PM
Subject: [External] RE: Getting error in setting up NFS
Tushar,
Have you checked that you can ping the target from the host?
Yes, I could able to ping the target from the host and vice versa. (I did it in both ways – 1. Linux PC <-> Xilinx board Petalinux 2. Linux PC <-> another Linux PC)
Have you verified that the nfs server is working properly by trying to connect from another PC?
Yes, NFS is working perfectly in a PC, I checked it using a command for NFS services status, as follows:
> systemctl status nfs-server.services
  • nfs-server.service - NFS server and services
   Loaded: loaded (/usr/lib/systemd/system/nfs-server.service; enabled; vendor preset: disabled)
  Drop-In: /run/systemd/generator/nfs-server.service.d
           └─order-with-mounts.conf
   Active: active (exited) since Tue 2018-06-05 11:59:57 IST; 1 day 5h ago
  Process: 18311 ExecStopPost=/usr/sbin/exportfs -f (code=exited, status=0/SUCCESS)
  Process: 18309 ExecStopPost=/usr/sbin/exportfs -au (code=exited, status=0/SUCCESS)
  Process: 18305 ExecStop=/usr/sbin/rpc.nfsd 0 (code=exited, status=0/SUCCESS)
  Process: 18330 ExecStart=/usr/sbin/rpc.nfsd $RPCNFSDARGS (code=exited, status=0/SUCCESS)
  Process: 18325 ExecStartPre=/bin/sh -c /bin/kill -HUP `cat /run/gssproxy.pid` (code=exited, status=0/SUCCESS)
  Process: 18323 ExecStartPre=/usr/sbin/exportfs -r (code=exited, status=0/SUCCESS)
Main PID: 18330 (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/nfs-server.service
Jun 05 11:59:56 localhost.localdomain systemd[1]: Starting NFS server and ser...
Jun 05 11:59:57 localhost.localdomain systemd[1]: Started NFS server and serv...
Hint: Some lines were ellipsized, use -l to show in full.
And I was able to mount NFS share in another PC successfully using this command.
> sudo mount -t nfs XXX.XXX.X.XXX(IP of NFS server):/nfs_share /mnt/nfs_mount
It displayed all the content from nfs_share into nfs_mount.
Christophe
Sent: 05 June 2018 05:27 PM
Subject: Getting error in setting up NFS
Hi Pablo and Christophe,
I am working on ZCU102 development board with Xilinx Zynq ultrascale+ for one of our pre-product development. I am using Petalinux SDK environment to build the required boot software and petalinux for the board.  For my prototype study, I need to host the linux filesystem from a NFS server. I am facing issues in mounting the NFS filesystem and I request your team support in getting the help. You can find the details of the steps here.
I am using RHEL desktop PC for running the NFS server and file system from the NFS share. I followed the below steps to mount the NFS filesystem.
On Server side (RHEL desktop PC) -
  1. Installed NFS services using command - sudo yum install nfs­kernel­server nfs­common portmap
  2. Modify the /etc/exports file with text - /nfs_share/ *(rw,sync,no_root_squash)
  3. Restart the NFS server using command: sudo systemctl restart nfs-server.service
On NFS client side (ZynqMP ultrascale+) –
  1. image.ub and BOOT.BIN are generated as follows.
  • Changed directory to petalinux project extracted using .bsp file.
  • Executed the command -  source /opt/pkg/petalinux/settings.sh
  • Executed the command -  petalinux-config
  • In .config settings went to Image Packaging Configuration and change the fields as follows-
Root filesystem type is selected as NFS.
Location of NFS root directory is edited as /nfs_share
NFS server IP address is filled with RHEL desktop’s ethernet IP.
went back and
  • Chose DTG settings and edited the Kernel Bootargs as below –
console=ttyPS0,115200 root=/dev/nfs nfsroot=XXX.XXX.X.XXX(IP of RHEL machine):/nfs_share, tcp ip=dhcp rw
save the config and exit.
  • Executed the command - petalinux-build
  • Executed the command - petalinux-package --boot --fsbl (path to zynqmp_fsbl.elf) --fpga (path to download.bit) --pmufw (path to pmufs.elf) --u-boot --force
  • Load the image.ub and BOOT.BIN file in boot partition of SDcard and boot into board.
Getting the following errors
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "nfs" or unknown-block(2,0): error -6
Please append a correct "root=" boot option;
Kernel panic - not syncing: VFS: Unable to mount root fs
Tushar
