ptg
Getting simple output with Xilinx DRM KMS framework
I'm trying to get Linux framebuffer output with VDMA and AXI4-Stream to Video Out.
The PL Display driver in Xilinx DRM KMS seems to provide CRTC which is to be connected with DRM encoder and DRM connector implemented in HDMI Tx, DSI Tx, SDI Tx drivers. As I don't need any real PHY, any of them are not applicable. I just want a plain, fixed resolution DRM encoder + connector.
I thought of making dummy DRM encoder + connector based on them but the DRM stack is way too complicated to understand. It's great to have official way to get it.
I read:
DPDMA graphics stack via live output->PL (no physical display port connection)
ZCU102: How to pass GPU output to the PL
My old post to get framebuffer with DPDRM:
Mali 3D w/o DP PHY
hokim
There seems to be no way except you learn from linux source code.
Write your driver like
https://github.com/Xilinx/linux-xlnx/blob/master/drivers/gpu/drm/xilinx/xilinx_drm_dsi.c
https://github.com/Xilinx/linux-xlnx/blob/master/drivers/gpu/drm/xilinx/xilinx_drm_sdi.c
The followings show how to write devicetree for your driver
https://github.com/Xilinx/linux-xlnx/blob/master/Documentation/devicetree/bindings/drm/xilinx/xilinx_drm.txt (Example 4)
https://github.com/Xilinx/linux-xlnx/blob/master/Documentation/devicetree/bindings/drm/xilinx/dsi.txt
https://github.com/Xilinx/linux-xlnx/blob/master/Documentation/devicetree/bindings/drm/xilinx/sdi.txt
Note how to use the following functions  in the above source codes.
drm_encoder_init, drm_encoder_helper_add, drm_connector_init, drm_connector_helper_add, drm_connector_register, drm_mode_connector_attach_encoder
ptg
@hokim Thanks for your post, but unfortunately the DRM driver you showed is the old one. The new one, drivers/gpu/drm/xlnx, has "Modular structure" according to Changelog. I guess drivers/gpu/drm/xlnx/xlnx_pl_disp.c stands for a split "module" which provides a Plane and a CRTC for encoders, while DPDRM has its own CRTC impl in it.
hokim
ptg
I managed to get a dummy Encoder and Connector with my dummy driver (based on DSI driver, just disabled read/write of registers) .
Device tree:
        dummy {
                status = "okay";
                compatible = "xlnx,dummy";
                xlnx,dsi-num-lanes = <0x4>;
                xlnx,dsi-data-type = <0x0>;
                #address-cells = <0x1>;
                #size-cells = <0x0>;
                port@0 {
                        reg = <0x0>;
                        endpoint {
                                remote-endpoint = <0x37>;
                                linux,phandle = <0x38>;
                                phandle = <0x38>;
                simple-panel@0 {
                        compatible = "dummypanel";
                        reg = <0x0>;
        drm-pl-disp-drv {
                compatible = "xlnx,pl-disp";
                dmas = <0x36 0x0>;
                dma-names = "dma0";
                xlnx,vformat = "RGB8";
                port@0 {
                        endpoint {
                                remote-endpoint = <0x38>;
                                linux,phandle = <0x37>;
                                phandle = <0x37>;
and modified drivers/gpu/drm/panel/panel-simple.c to specify the panel info.
Successfully my kernel probed it and /dev/fb0 is visible but Xorg doesn't work.
I found a bug in drivers/drm/xlnx/xlnx_crtc.c Line 52.
-- #define XLNX_CRTC_MAX_HEIGHT_WIDTH  UINT_MAX
++ #define XLNX_CRTC_MAX_HEIGHT_WIDTH  INT_MAX
UINT_MAX will be interpret as -1 in Xorg somehow and leads to misunderstand max resolution.
[    17.972] (II) ARMSOC(0): drmmode_pre_init:1682 Got KMS resources
[    17.972] (II) ARMSOC(0): drmmode_pre_init:1685   1 connectors, 1 encoders
[    17.972] (II) ARMSOC(0): drmmode_pre_init:1688   1 crtcs, 0 fbs
[    17.972] (II) ARMSOC(0): drmmode_pre_init:1691   0x0 minimum resolution
[    17.972] (II) ARMSOC(0): drmmode_pre_init:1694   -1x-1 maximum resolution
this will be fixed like
[    17.972] (II) ARMSOC(0): drmmode_pre_init:1694   2147483647x2147483647 maximum resolution
Also dug into xf86-video-armsoc (armsoc_drv.so). This will die by SIGSEGV when it calls xf86CrtcRotate(). After skipping it, X still dies by EINVAL.
[    18.009] (EE) ARMSOC(0): ERROR: drm failed to set mode: Invalid argument
[    18.010] (II) ARMSOC(0): drmmode_revert_mode:235 No last good values to use
[    18.010] (II) ARMSOC(0): drmmode_set_mode_major:445: Exiting
I gave up digging xf86 API which is too deep to dive in.
My initial motivation to use PL Display was avoiding DPDRM which is still unavailable to use without PHY. (Recently initialization without PHY patch is added but it disables the CRTC and we can't use Xorg on it)
liufengwuhen
请问你最后怎么解决的,我也遇到了同样的问题。
