Visitor mdudley
Getting started with Zynq 14.5 and QEMU
Hi all,
I'm trying to set up a virtual environment that I can use to test software for the ZC706. I don't need anything fancy, just a plain vanilla environment where I can run a C++ "Hello World" program compiled for ARM. I gave QEMU a shot by following the instructions on the wiki but I have not been successful.
I think others have had similar trouble:
Here is exactly what I have done on a Windows 7 machine:
  1. Downloaded and installed VirtualBox 4.2.12. Created a VM with Ubuntu 12.04.2 Desktop 64-bit and 2 GB of memory, and upgraded all packages to latest.
    sudo apt-get update
    sudo apt-get upgrade
  2. Installed QEMU dependencies.
    sudo apt-get install build-essential git-core flex bison libglib2.0-dev libpixman-1-dev zlib1g-dev
  3. Cloned the Xilinx QEMU project into my home directory.
    cd
    git clone git://git.xilinx.com/qemu.git
    cd qemu
    git checkout xilinx-master
  4. Ubuntu does not appear to support the "DTC devel" package that QEMU requires (I tried installing the device-tree-compiler and libfdt-dev packages, but neither made a difference). So I added the submodule:
    git submodule update --init dtc
  5. Configured and built QEMU (had to limit the number of jobs or else my VM ran out of memory):
    ./configure --target-list="arm-softmmu,microblazeel-softmmu" --enable-fdt --disable-kvm
    make -j4
  6. Obtained and extracted the Zynq 14.5 images:
    cd
    mkdir zynq-14.5
    cd zynq-14.5
    wget http://www.wiki.xilinx.com/file/view/14.5-release.tar.xz/426726708/14.5-release.tar.xz
    tar xvJf 14.5-release.tar.xz
  7. Attempted to start the virtual environment:
    cd
    ./qemu/arm-softmmu/qemu-system-arm -M arm-generic-fdt -nographic -serial mon:stdio -dtb zynq-14.5/zc70x/zc706/devicetree.dtb -kernel zynq-14.5/uImage -initrd zynq-14.5/uramdisk.image.gz -machine linux=on -smp 2
This is where I ran into trouble. The machine did not start, I got the message "No filesystem could mount root."
I got the following output:
console [ttyPS0] enabled, bootconsole disabled
xdevcfg f8007000.devcfg: ioremap f8007000 to f0060000 with size 100
: r_unlock_post_write: successful unlock
brd: module loaded
loop: module loaded
xqspips e000d000.spi: master is unqueued, this is deprecated
m25p80 spi1.0: n25q128 (32768 Kbytes)
5 ofpart partitions found on MTD device spi1.0
Creating 5 MTD partitions on "spi1.0":
0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
0x000000100000-0x000000600000 : "qspi-linux"
0x000000600000-0x000000620000 : "qspi-device-tree"
0x000000620000-0x000000c00000 : "qspi-rootfs"
0x000000c00000-0x000002000000 : "qspi-bitstream"
xqspips e000d000.spi: at 0xE000D000 mapped to 0xF0062000, irq=51
e1000e: Intel(R) PRO/1000 Network Driver - 2.1.4-k
e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: invalid address, use assigned
xemacps e000b000.eth: MAC updated a6:03:ef:b9:9d:0c
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci-pci: EHCI PCI platform driver
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
xi2cps e0004000.i2c: 100 kHz mmio e0004000 irq 57
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
i2c i2c-0: Added multiplexed i2c bus 3
at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 4
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
usbhid: USB HID core driver
TCP: cubic registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 0
dmatest: Started 1 threads using dma0chan0
dmatest: Started 1 threads using dma0chan1
dmatest: Started 1 threads using dma0chan2
dmatest: Started 1 threads using dma0chan3
dmatest: Started 1 threads using dma0chan4
dmatest: Started 1 threads using dma0chan5
dmatest: Started 1 threads using dma0chan6
dmatest: Started 1 threads using dma0chan7
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Sending DHCP requests ., OK
IP-Config: Got DHCP answer from 10.0.2.2, my address is 10.0.2.15
IP-Config: Complete:
     device=eth0, hwaddr=a6:03:ef:b9:9d:0c, ipaddr=10.0.2.15, mask=255.255.255.0, gw=10.0.2.2
     host=10.0.2.15, domain=, nis-domain=(none)
     bootserver=10.0.2.2, rootserver=10.0.2.2, rootpath=
     nameserver0=10.0.2.3RAMDISK: Couldn't find valid RAM disk image starting at 0.
List of all partitions:
1f00            1024 mtdblock0  (driver?)
1f01            5120 mtdblock1  (driver?)
1f02             128 mtdblock2  (driver?)
1f03            6016 mtdblock3  (driver?)
1f04           20480 mtdblock4  (driver?)
No filesystem could mount root, tried:  ext3 ext2 ext4 vfat msdos
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(1,0)
CPU0: stopping
[<c00142d0>] (unwind_backtrace+0x0/0x11c) from [<c00131e0>] (ipi_cpu_stop+0x3c/0x6c)
[<c00131e0>] (ipi_cpu_stop+0x3c/0x6c) from [<c0013460>] (handle_IPI+0x60/0xa4)
[<c0013460>] (handle_IPI+0x60/0xa4) from [<c00084e0>] (gic_handle_irq+0x58/0x60)
[<c00084e0>] (gic_handle_irq+0x58/0x60) from [<c000e140>] (__irq_svc+0x40/0x70)
Exception stack(0xee1b3e20 to 0xee1b3e68)
3e20: ee361ac0 00000158 000000d4 000000d4 00000000 000000c0 00000158 ee361ac0
3e40: ee35c000 00000000 00001e14 ffffff67 00003a58 ee1b3e68 c01e5be4 c03b5364
3e60: 80000113 ffffffff
[<c000e140>] (__irq_svc+0x40/0x70) from [<c03b5364>] (dmatest_verify+0x2c/0x11c)
[<c03b5364>] (dmatest_verify+0x2c/0x11c) from [<c01e5be4>] (dmatest_func+0xc3c/0xe64)
[<c01e5be4>] (dmatest_func+0xc3c/0xe64) from [<c003acb4>] (kthread+0xa0/0xb0)
[<c003acb4>] (kthread+0xa0/0xb0) from [<c000e5d8>] (ret_from_fork+0x14/0x3c)
One other interesting point is that I downloaded zynq_linux.tar.gz and had no trouble running it using ./start_qemu.sh. Unfortunately this download doesn't appear to be mentioned anywhere on the Xilinx site now, so I get the impression that it is outdated and not supported?
Tags (2)
Re: Getting started with Zynq 14.5 and QEMU
Problem solved: The qemu's '-initrd' switch expects a plain initrd/initramfs. Not one with a u-boot header. Stripping the u-boot header from the uramdisk.image.gz file works. I think I'll upload that file to the wiki later. To remove the u-boot header from the uramdisk.image.gz file use the following command:
dd if=./uramdisk.image.gz of=./ramdisk.image.gz skip=16 bs=4
And then use the file 'ramdisk.image.gz' to boot on qemu.
I have to admit, I didn't test the images with qemu and doing so gains the same result you see.
We'll look into this. Please have some patience.
