jklebau
Git server for MicroBlaze tools - Connection Refused?
When I try to "git" the MicroBlaze GNU toolchain referenced on this page http://xilinx.wikidot.com/mb-gnu-tools , I get
the followng error:
ubuntu:~$ git clone git://git.xilinx.com/microblaze-gnu.git
Cloning into 'microblaze-gnu'...
fatal: unable to connect to git.xilinx.com:
git.xilinx.com[0: 149.199.60.191]: errno=Connection refused
Is this an error on my end, or Xilinx's side?
vijayak
Please check if this helps.
http://forums.xilinx.com/t5/Embedded-Linux/Unable-to-download/td-p/261062
Thanks,Vijay
jklebau
When I try from within the NASA corporate domain, I get errno=Connection timed out.
If I browse the Github https://github.com/Xilinx, I don't find anything dealing with the MicroBlaze. When I search for "microblaze-git", the results are empty. Is that repository still online?
