truessd
Github `issues` only for several repos enabled
I realized that the `issues` section on github is only enabled for a couple of repos. E.g. `meta-xilinx-tools` has it enabled and `meta-xilinx` does NOT.
What would be the right place to submit a bug report / issue for `meta-xilinx`?
florentw
Hi @truessd
You might want to refer to the following wiki page for the support of Xilinx embedded:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841631/Embedded+SW+Support
Florent
florentw
Hi @truessd
Florent
