Scholar vanmierlo
GnuPG in petalinux 2016.4
In the petalinux 2016.4 installation directory I see something resembling a recipe for GnuPG:
petalinux-v2016.4/components/yocto/source/arm/layers/poky/meta/recipes-support/gnupg/gnupg_2.1.11.bb
How is one supposed to enable this recipe so gpg gets installed in my rootfs?
Maarten
Re: GnuPG in petalinux 2016.4
Since petalinux 2016.4 is based out of yocto build system, you can try the following way to add gnupg package:
I could see gnupg related code resides in the below path:
Normally, In meta-petalinux, packagegroup-petalinux.bb contains the information about all the packages being built for each architecture.
Lets add the desired package at the end of ZYNQ_EXTRAS, which you can find in below path:
components/yocto/source/arm/layers/meta-petalinux/recipes-core/packagegroups/packagegroup-petalinux.bb
Please give the above try and let me know if it works for you.
Best Regards
Shabbir
Best Regards
Shabbir
Scholar vanmierlo
That seems to work :)
It feels a bit odd to have to modify files in the petalinux 2016.4 installation. Maybe one can do something like ZYNQ_EXTRAS += "gnupg" in some .bb file as well. I'm still open for suggestions on that.
But after I edited packagegroup-petalinux.bb as described and ran petalinux-config -c rootfs I could now select gnupg.
Maarten
You can do this by editing the "<plnx-proj-root>/project-spec/meta-plnx-generated/recipes-core/i
mages/petalinux-image.bbappend" file in your project. See the "Adding a Recipe from the Layers in SDk which are
not in petalinux-image.bb" section of UG1144, "PetaLinux Tools Documentation Reference Guide".
Add this line to  <petalinux-project>/project-spec/meta-user/conf/layer.conf:
IMAGE_INSTALL_append +=" gnupg"
