Anonymous
Not applicable
Got stuck on Calibrating delay loop...
I was following the instructions on http://wiki.xilinx.com/zynq-linux#toc7
git clone git://git.xilinx.com/linux-xlnx.git
make ARCH=arm xilinx_zynq_defconfig
make ARCH=arm
After I replaced zImage on my SD card, I got:
WARNING: at arch/arm/mach-zynq/timer.c:299 xttcpss_timer_init+0x64/0x248()
Modules linked in:
[<c0012928>] (unwind_backtrace+0x0/0xe0) from [<c001e84c>] (warn_slowpath_common+0x4c/0x64)
[<c001e84c>] (warn_slowpath_common+0x4c/0x64) from [<c001e87c>] (warn_slowpath_null+0x18/0x1c)
[<c001e87c>] (warn_slowpath_null+0x18/0x1c) from [<c0412f4c>] (xttcpss_timer_init+0x64/0x248)
[<c0412f4c>] (xttcpss_timer_init+0x64/0x248) from [<c040fb38>] (time_init+0x20/0x2c)
[<c040fb38>] (time_init+0x20/0x2c) from [<c040c66c>] (start_kernel+0x1a0/0x304)
[<c040c66c>] (start_kernel+0x1a0/0x304) from [<00008044>] (0x8044)
---[ end trace 1b75b31a2719ed1c ]---
xlnx,ps7-ttc-1.00.a #0 at 0xf0000000, irq=0
Did I miss anything?
Haibing
Anonymous
Not applicable
Sorry I didn't see the other thread. Recompiled device tree and the kernel is happy.
Haibing
