gsanthar
Hard float app in Petalinux 2016.1 gives just shows a very few rise in benchmark performance results
One of the Main Features in Petalinux 2016.1 is to have support for hard float compiler option.
I want to find the difference between new hard float point compiler and old softfp one. In relation to this
I executed classic benchmark test for floating point operation such as whetstone and linpack using both the hard floating and softp compiler.
But I found a marginal increase in the benchmark performance after moving to hard float point compiler. which is hard to comprehend.
I was expecting atleast 50% increase in performance with hard floating point compiler
Results are below
Soft Floating Point Compiler:
Whetstone Tests Results:
  Assembler CPUID and RDTSC
  CPU Cortex A8, Features Code 00000000, Model Code 00000000
  Measured - Minimum 1000 MHz, Maximum 1000 MHz
  Linux Functions
  get_nprocs() - CPUs 2, Configured CPUs 2
  get_phys_pages() and size - RAM Size  0.98 GB, Page Size 4096 Bytes
  uname() - Linux, OP4200_SD, 4.0.0-xilinx
  #1 SMP PREEMPT Wed Jun 22 15:51:12 EDT 2016, armv7l
Whetstone Single Precision C Benchmark  Opt 3 64 Bit, Sat Jan  3 15:39:31 1970
Loop content                   Result              MFLOPS      MOPS   Seconds
N1 floating point      -1.12475013732910156       186.039               0.052
N2 floating point      -1.12274742126464844       187.355               0.361
N3 if then else         1.00000000000000000               19465.812     0.003
N4 fixed point         12.00000000000000000                 829.160     0.191
N5 sin,cos etc.         0.49911010265350342                   9.595     4.361
N6 floating point       0.99999982118606567       147.482               1.840
N7 assignments          3.00000000000000000                5972.144     0.016
N8 exp,sqrt etc.        0.75110864639282227                   5.919     3.161
MWIPS                                             503.795               9.984
Results  to  load  to  spreadsheet        MWIPS   Mflops1   Mflops2   Mflops3   Cosmops   Expmops  Fixpmops    Ifmops    Eqmops
Results  to  load  to  spreadsheet      503.795   186.039   187.355   147.482     9.595     5.919   829.160 19465.812  5972.144
  Linux Functions
  uname() - Linux, petalinux_new, 4.4.0-xilinx
  #6 SMP PREEMPT Tue Jun 21 15:53:06 EDT 2016, armv7l
Whetstone Single Precision C Benchmark  Opt 3 64 Bit, Thu Jan  1 00:03:25 1970
N1 floating point      -1.12475013732910156       186.290               0.053
N2 floating point      -1.12274742126464844       187.359               0.368
N3 if then else         1.00000000000000000                9918.454     0.005
N4 fixed point         12.00000000000000000                 819.753     0.197
N5 sin,cos etc.         0.49911010265350342                   9.994     4.271
N6 floating point       0.99999982118606567       147.493               1.876
N7 assignments          3.00000000000000000                5968.970     0.016
N8 exp,sqrt etc.        0.75110864639282227                   5.941     3.212
MWIPS                                             513.071               9.999
Results  to  load  to  spreadsheet      513.071   186.290   187.359   147.493     9.994     5.941   819.753  9918.454  5968.970
Is there benchmark performance results available for Xilinx Zc702 Mercrury board from Xilinx. If so can you please share the results
guillaumebres
I suppose the second results are the one using the FPU right?
I increased my amount of MFlops by 20 using the FPU on the zc706 (I don't use petalinux).
Can you show us the command line you used (especially the -flags) when you compiled the program?
here's what I did:
gcc -o main main.c -0fast -ffast-math -mcpu=cortex-a9 -mfpu=neon
gw.
Embedded Systems, DSP, cyber
muzaffer
does "increased my amount of MFlops by 20 using the FPU on the zc706" mean that MFlops went up roughly by 10% ?
guillaumebres
@muzaffer,
I meant by a factor of 20,
this was between an embedded OS without any support for the FPU and a Neon optimized system.
Download the attached image to see it properly
gw.
muzaffer
this is not a really interested test. I'm looking for numbers where the difference is hard float vs not. Any idea what that difference would be ?
guillaumebres
I have never compared virtual floating point against floating point in hardware
gw.
milosoftware
Usually results like this are the result of changing the float ABI, not the FPU itself.
All build environments for the Zynq use the vfp and neon floating point instructions by default. Many use the "softfp" ABI, which still uses the FPU but exchanges data with libraries using the CPU registers instead of FPU registers. This makes the library compatible with both hard- and softfloat machines. This is marginally slower than hardfloat ABI.
As for neon and vfp, since having neon implies vfp, the compiler will decide which is to be used and will already make the correct choice, no need to disable one or the other.
As for benchmarking, "hard" float implementations usually run at least 10x faster than their software-only counterparts.
