Having problems with Ethernet 10G on petalinux 2018.3
Hi all, I've designed with my VC707 board a system with microblaze running  Linux. Also, I'm using the IP 10G ethernet subsystem.
When running ping from FPGA to another place on the network everything works well, however running ping from some place on the net to FPGA the packet gets big(ranging from 33% to 66%). Can anyone help me?
Edit : Here is the hdf file
HI @jamellyf
Do you have the design HDF?
Yes, I've attached it to the original message sorry
