Heat up the processors
I'm using Zynq Ultrascale+ quad core chips with Linux in SMP(symmetric multi processing).
In order to test the capability of our cooling system, i want to make all the quad A53 processors to work under their maximum work load to reach the maximum power consumption.
Do you have some experience how to implement this?
Re: Heat up the processors
    use cpuburn-arm
https://github.com/ssvb/cpuburn-arm
Compilation instructions:
* $ aarch64-linux-gnu-gcc -o cpuburn-a53 cpuburn-a53.S
i ran 8 daemons of cpuburn-a53 [i.e. cpuburn-a53& 8 times]
the combined cpu utilized was 99.1%
and after sometime board shutdown [expected,becz of onboard temp sensor]
Scholar austin
s,
Generally, just clocking all cores, is the most power you are likely to get.  Execution of instructions differs little.  So just running petalinux is likely to be a good data point.  You may wish to create a script to run that encrypts, zips, unzips, decrypts and does a diff.  Launching them with & at the end of the command (each command should use a different file so they do not block and wait for each other).
That way, the process, if not blocked, gets assigned to another free core.
so
gzip foo1&
gzip foo2&
gzip foo3&
(etc.)
The power increase will almost completely be in the added DDR memory interface traffic, but you might be able to see an increase in PSVccint current as well.
Austin Lesea
Principal Engineer
Xilinx San Jose
@austin, Thank you for the feedback. It's helpful.
I'm using peta-Linux. How to make sure all cores have been clocked?  Is there a way to know the real-time workload of each core?
Scholar austin
The base trd uses all 4 A53 cores.  The Dual R5's are not used.  You may want to add them to your design (perhaps run ubuntu on them),
top will display running process.  There are other commands as well to show usage.  Just google 'linux process information'
One such site:
http://www.linuxtopia.org/online_books/introduction_to_linux/linux_Displaying_process_information.html
Austin Lesea
Principal Engineer
Xilinx San Jose
    use cpuburn-arm
Scholar austin
What board?
I am surprised it shut down.  If the board's Vccintps current limit is set too low, that would explain it.  But over-temp would be unusual, unless the PL was already running quite hot, and heatsinking was insufficient.
I believe the max power of the PS is ~ 6 watts, so the PS alone is unlikely to cause overtemp?
Austin Lesea
Principal Engineer
Xilinx San Jose
