shairva
Help on adding python3-pip to Petalinux
I need to add python3-pip to my Petalinux.
1- First thing I did was to open ./project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend and append:
IMAGE_INSTALL_append = " python3-pip"
 2- Second thing I did: I looked for the recipe: https://layers.openembedded.org/layerindex/recipe/53469/
python3-pip is available on the layer: openembedded-core (morty branch)
3- Now I think I need to add that layer to: ./build/conf/bblayers.conf But I don't exactly how to do that.
This is my current ./build/conf/bblayers.conf :
# WARNING: this configuration has been automatically generated and in
# most cases should not be edited. If you need more flexibility than
# this configuration provides, it is strongly suggested that you set
# up a proper instance of the full build system and use that instead.
LCONF_VERSION = "7"
BBPATH = "${TOPDIR}"
SDKBASEMETAPATH = "/home/salva/petalinux_2019.1/components/yocto/source/aarch64"
BBLAYERS := " \
  ${SDKBASEMETAPATH}/layers/core/meta \
  ${SDKBASEMETAPATH}/layers/core/meta-poky \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-perl \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-python \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-filesystems \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-gnome \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-multimedia \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-networking \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-webserver \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-xfce \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-initramfs \
  ${SDKBASEMETAPATH}/layers/meta-openembedded/meta-oe \
  ${SDKBASEMETAPATH}/layers/meta-browser \
  ${SDKBASEMETAPATH}/layers/meta-qt5 \
  ${SDKBASEMETAPATH}/layers/meta-xilinx/meta-xilinx-bsp \
  ${SDKBASEMETAPATH}/layers/meta-xilinx/meta-xilinx-contrib \
  ${SDKBASEMETAPATH}/layers/meta-xilinx-tools \
  ${SDKBASEMETAPATH}/layers/meta-petalinux \
  ${SDKBASEMETAPATH}/layers/meta-virtualization \
  ${SDKBASEMETAPATH}/layers/meta-openamp \
  ${SDKBASEMETAPATH}/workspace \
  /home/salva/petalinux_2019.1/dpu_without_bsp/project-spec/meta-plnx-generated \
  /home/salva/petalinux_2019.1/dpu_without_bsp/project-spec/meta-user \
Can I have some help on this please?
Thanks in advance
stephenm
The openembedded layer are already added with Petalinux/Yocto:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841883/Yocto
In this case, just look for the recipe you want to add:
https://layers.openembedded.org/layerindex/recipe/37578/
Then just add this to the rootfs
Pre 2020.1:
<plnxproj-root>/project-spec/meta-user/recipes-core/images/petalinux-imagefull.bbappend file. For example:
IMAGE_INSTALL_APPEND = " python3-pip"
Post 2020.1:
<plnx-proj-root>/project-spec/meta-user/conf/user_rootfsconfig
CONFIG_python3-pip
Reference:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug1144-petalinux-tools-reference-guide.pdf
stephenm
shairva
Hi @stephenm ,
I read that post before creating this one, but it is not clear to me how to add the layer and the recipe.
Can you please help me with that?
Thanks in advance.
shairva
1 - I did: git clone https://git.openembedded.org/openembedded-core (inside folder project-spec)
2- $ petalinux-config
Yocto Settings ->
user layers ->
user layer 0 ->
path_to_my_layer
3- Save and exit.
Result:
ERROR: Failed to add user layer: /home/user/petalinux_2019.1/my_project/project-spec/openembedded-core/
ERROR: Failed to config project.
stephenm
Pre 2020.1:
Post 2020.1:
CONFIG_python3-pip
Reference:
stephenm
I tried this on my end, and it works:
shairva
ohhhh I thought the command to invoke was python3-pip, facepalm
I typed pip3 as you did and, yes, I got it:
root@design_one:~# pip3 --version
pip 20.0.2 from /usr/lib/python3.5/site-packages/pip (python 3.5)
root@design_one:~#
So, @stephenm, I thought openembedded-core and meta-openembedded were different layers, that's why I though that layer was not included with Petalinux
Thanks!
