Heterogeneous Multi-Processor Linux for ZCU102
Hi, colleagues,
I'm working on the embedded linux on ZCU102. I'm able to run to Linux on the four APUs.
I'm wondering if there is any HMP Linux-branch could run on both APUs and RPUs?
Any idea will be appreciated,
Bests!
Re: Heterogeneous Multi-Processor Linux for ZCU102
Hi @siriuxliu ,
You can not run RPU on Linux you can run RPU on baremetal and APU on Linux.
And also petalinux doesn't support multiprocessors.
Thanks & Regards,
Shubhangi
Thanks, Shubhangi :)
Any possible ways that APU run linux and send workload to RPU?
Bests!
Hi @siriuxliu ,
Yes, you can use openAMP and libmetal to share the workload.
Please refer to UG1186 which describes how to develop a methodology to enable communication
between multiple processors on Xilinx® Zynq® and Zynq UltraScale+™ MPSoC platforms.
Kindly note- Please mark the Answer as "Accept as solution" if the information provided is helpful.
Give Kudos to a post that you think is helpful and reply oriented.
