How can I generate a BSP for linux
Accepted Solution Solved
Accepted Solution
Now I can run some simple examples in ZC702 board without linux OS. We know that there will be a BSP.
But if I want to run a linux OS in ZC702, I think that I must build all ip drivers into the linux kernel. That is to say ,I should generate a BSP for kernel.
How can I do that ?
Thanks. need your help.
Chen.
Re: How can I generate a BSP for linux
If you want to use an IP in a Linux program, you'll have to write a driver to do that.
For some devices, you can get away with a standard "pass througg" driver that just maps the memory area into your application. The "devmem" program does this on the commandline, in a C/C++ program you can do the same by opening "/dev/mem" and then mmap the physical memory range for direct access.
This will work for plain AXI memory-like access. If you need to handle interrupts or DMA transfers, then you'll have to write a real driver (the "bible" on writing drivers: http://www.makelinux.net/ldd3/).
All Replies
Please follow the steps
1. In SDK File--> New Application Project
2. In the window that opens, Select Linux as the Os Platform
3. In the next window, select Linux Hello World under Available templates and click Finish.
This should create a hello world application including the BSP in Linux.
If you are using Zynq, please refer to chapter 5 and chapter 9 tof the following guide to learn how to boot linux and execute the application.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug873-zynq-ctt.pdf
I think you dont understand what does I mean.
There is example design of UG925. Now there are some IP which is implemented by PL, but I want to my application can
control these IPs. I think that the drivers of all IPs must be built into linux kernel. How can I do this ?
For example, if there is no linux os, there will genertate a  BSP to support to configure AXI_VDMA.   There are some codes which is offered by xilinx.
    Config = XAxiVdma_LookupConfig(VDMA_DEVICE_ID);
    if (!Config) {
        xil_printf(
            "No video DMA found for ID %d\r\n", VDMA_DEVICE_ID);
        return XST_FAILURE;
    /* Initialize DMA engine */
    Status = XAxiVdma_CfgInitialize(&AxiVdma, Config, Config->BaseAddress);
    if (Status != XST_SUCCESS) {
        xil_printf(
            "Configuration Initialization failed %d\r\n", Status);
        return XST_FAILURE;
But if I wanto run some application on linux.  how can I call this function "XAxiVdma_CfgInitialize()" ?
Thanks. Need your help.
XAxiVdma_CfgInitialize is coded in bare metal, and this function operates on registers.
As to linux drivers, we need use ioremap to map register address to virtual address. After this, we can use ioread or iowrite to manipulate virtual address.
So, this function can't be used in linux driver.
milosoftware wrote:
(the "bible" on writing drivers: http://www.makelinux.net/ldd3/ )
Fixed that link for you. (it included the ")." at the end)
Also, I found this link to be useful
http://www.wiki.xilinx.com/Linux+User+Mode+Pseudo+Driver
It more specifically mentions using /dev/mem and mmap() to map memory for a driver
And here is some info about the mmap() function
http://man7.org/linux/man-pages/man2/mmap.2.html
Hi, thanks for all your advices.
Yes, I have know that now.
Writing a linux driver for one  IP which is implemented by PL is some trouble.
If Xilinx can offer some linux driver for their IP cores, Isn't it good ?
Thanks to you all.
Chen.
You will find the Linux drivers at:
http://www.wiki.xilinx.com/Linux+Drivers
Also, you might want to look at:
https://github.com/Xilinx/linux-xlnx
Note that if you instantiate, for example, a 16550 UART in PL, you can use the generic 16550 driver to control it, and need not write a driver yourself.
Lots of logic can be made to look like existing hardware. Some logic cores, like the opencore ones, come with existing drivers. So if you write an audio device in logic, outputting the sound like a class-D device on a logic pin, you could make it look like an existing device and use that device's driver to control it.
If you have a custom device that processes data, you can also wait for Dyplo to be released. That'll let you control the data flows using code or even shell commands to move the data around between logic, CPU and I/O parts.
