Visitor dundun1128
How can I use AXI Stream-FIFO with Linux OS
How can I use  AXI Stream-FIFO with Linux OS, should I write FIFO driver by myself?
I have bulid my own BOOT.bin devicetree uImage and I use linux for my OS.
Here's my part pl.dtsi code :
axi_fifo_mm_s_0: axi-fifo-mm-s@43c00000 {
compatible = "xlnx,axi-fifo-mm-s-4.0";
interrupt-parent = <&ps7_scugic_0>;
interrupts = <0 29 4>;
reg = <0x43c00000 0x10000>;
xlnx,axi-str-rxd-protocol = "XIL_AXI_STREAM_ETH_DATA";
xlnx,axi-str-rxd-tdata-width = <0x20>;
xlnx,axi-str-txc-protocol = "XIL_AXI_STREAM_ETH_CTRL";
xlnx,axi-str-txc-tdata-width = <0x20>;
xlnx,axi-str-txd-protocol = "XIL_AXI_STREAM_ETH_DATA";
xlnx,axi-str-txd-tdata-width = <0x20>;
xlnx,axis-tdest-width = <0x4>;
xlnx,axis-tid-width = <0x4>;
xlnx,axis-tuser-width = <0x4>;
xlnx,data-interface-type = <0x0>;
xlnx,has-axis-tdest = <0x0>;
xlnx,has-axis-tid = <0x0>;
xlnx,has-axis-tkeep = <0x0>;
xlnx,has-axis-tstrb = <0x0>;
xlnx,has-axis-tuser = <0x0>;
xlnx,rx-fifo-depth = <0x1000>;
xlnx,rx-fifo-pe-threshold = <0x2>;
xlnx,rx-fifo-pf-threshold = <0xfd2>;
xlnx,s-axi-id-width = <0x4>;
xlnx,s-axi4-data-width = <0x20>;
xlnx,tx-fifo-depth = <0x1000>;
xlnx,tx-fifo-pe-threshold = <0x2>;
xlnx,tx-fifo-pf-threshold = <0xfd2>;
xlnx,use-rx-cut-through = <0x0>;
xlnx,use-rx-data = <0x1>;
xlnx,use-tx-ctrl = <0x1>;
xlnx,use-tx-cut-through = <0x0>;
xlnx,use-tx-data = <0x1>;
I want to know how can I control my FIFO like I use below function in standalone.
XLlFifo_Initialize(&fifo,AXI_FIFO_BASEADDR);
XLlFifo_Write(&fifo,&text,length);
XLlFifo_TxSetLen(&fifo,length);
Can anybody help me to figure out or offer example!!
Thanks in advance !!!!
Re: How can I use AXI Stream-FIFO with Linux OS
Please see the link below.
http://www.wiki.xilinx.com/Zynq+Linux+pl330+DMA
Sikta
Visitor dundun1128
Thanks your reply!
But my kernel vresion is xilinx-v2014.2 . It say the DMA330 driver is obsolete.
Can I just run it on xilinx-v2014.2 or I need to modify somewhere?
Thanks in advance.
Can you try just running it?
Sikta
Observer kevin.jesse
Is there a better solution than this? I am thinking I am going to have to write the FIFO driver. The pl330 depends on many non existant libraries that are not in petalinux 2014.
thanks,
kevin
Visitor dundun1128
Sorry, I'm so new to zynq.
I tried to compile "FIFO DMA Test Driver Source" with my cross-compile.
But it got many errors and I dont know how to figure it out. It seems does not have libraryor something is too old.
My kernel version is linux-xlnx-xilinx-v2014.2.
Thanks your reply!
