suheb
How do I create image.ub?
I followed the following link and got uimage
http://www.wiki.xilinx.com/Build+Kernel
Now I need image.ub and BOOT.BIn
BOOT.BIN I am already having and I know it can be created by the command petalinux-package
Now I need to create an image.ub having kernel and filesystem.
I am having my own initramfs.cpio and uimage and would like  to make an image.ub.
Any advice ? .
suheb
This link
http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Ubuntu+Desktop+on+Peta+Linux+Tech+Tip
says
image.ub = peta Linux image consists of kernel image, device tree blob and minimal rootfs
But no mention of how to make this image.ub.
justinlh
petalinux-build
ug980-petalinux-board-bringup would be a resource to look at
linnj
It seems like your mixing in non-Petalinux flow with Petalinux flow.  Petalinux allows you to point to a different kernel tree or u-boot tree and build it.  I would probably do that (configure Petalinux to point to a different area).
In the kernel configuration, using Petalinux, you can also point it to a different cpio image for your root filesystem. The kernel build combines the cpio image with the kernel image. The image.ub is a FIT image which is documented in the u-boot tree (doc/uImage.FIT).
lucywill
@justinlh wrote:
petalinux-build
ug980-petalinux-board-bringup would be a resource to look at on create image.ub
thank you, i will have a look at this resource.  do you have any tutorial that can teach me how to create such image, i am a new learner.
ransh
I have the same issue.
Is there a way to manually (not with petalinux) create image.ub in petalinux (from kernel and rootfs, so that we can first modify rootfs manually) "?
Thank you
sandeepg
Hi @ransh,
Below is the steps to create FIT image(image.ub) from command line without using petalinux. Make sure you change the ARCH for arm or aarch64 depending on your use case.
1. Create a fitImage.its file and add below content
$ vim fitImage.its
/dts-v1/;
    description = "U-Boot fitImage for plnx_aarch64 kernel";
    #address-cells = <1>;
    images {
        kernel@0 {
            description = "Linux Kernel";
            data = /incbin/("${TMPDIR}/deploy/images/${MACHINE}/Image");
            type = "kernel";
            arch = "arm64";
            os = "linux";
            compression = "none";
            load = <0x80000>;
            entry = <0x80000>;
            hash@1 {
                algo = "sha1";
        fdt@0 {
            description = "Flattened Device Tree blob";
            data = /incbin/("{TMPDIR}/deploy/images/${MACHINE}/zcu102-zynqmp-system.dtb");
            type = "flat_dt";
            arch = "arm64";
            hash@1 {
                algo = "sha1";
        ramdisk@0 {
            description = "ramdisk";
            data = /incbin/("{TMPDIR}/deploy/images/${MACHINE}/zcu102-zynqmp.cpio.gz.u-boot");
            type = "ramdisk";
            arch = "arm64";
            os = "linux";
            hash@1 {
                algo = "sha1";
    configurations {
        default = "conf@1";
        conf@1 {
            description = "Boot Linux kernel with FDT blob + ramdisk";
            kernel = "kernel@0";
            fdt = "fdt@0";
            ramdisk = "ramdisk@0";
            hash@1 {
                algo = "sha1";
        conf@2 {
            description = "Boot Linux kernel with FDT blob";
            fdt = "fdt@0";
            hash@1 {
                algo = "sha1";
2. Run mkimage command to generate the FIT image(image.ub). Make sure you install this u-boot tools package
$ mkimage -f fitImage.its image.ub
Note: Make sure you source the dtc tools path else you see this error
sh: 1: dtc: not found
mkimage: Can't read image.ub.tmp: Invalid argument
mkimage Can't add hashes to FIT blob
Sandeep
hanni_xu
reference to 'run.do_image_xilinx_fitimage'.
jahnavi_guvvala
Hii,
what are those paths?
/<PATH-TO-KERNEL-IMAGE>/zcu102-zynqmp/Image
do i need to install anything previously?
Jahnavi
sandeepg
Hi @jahnavi_guvvala ,
Once you have built Kernel, DTB and rootfs images, just specify the absolute path to Image, .dtb and rootfs.cpio.gz.u-boot
Sandeep
jahnavi_guvvala
It means i need to download petalinux and build it?
thanks,
Jahnavi
