How do I set eth0 link up script?
Hi All!
I want to execute script when eth0 links up.
I added my script file at /etc/network/if-up.d/.
And I pluged and unpluged lan cable.
But my script was not executed.
What is wrong?
Thank you!
Scholar watari
Re: How do I set eth0 link up script?
Hi @jrceokura
Here is solution for you.
$ inotifywait -e modify /sys/class/net/eth0/carrier; echo "Change detected !"
[note]
"inotify" API can monitor an event of file system on Linux.
In this case, you can detect change to use "inotifywait" with "-e modify" option.
Hi watari!
Thank you for your reply.
I tried your idea.
But I can't see "Change detected !".
In addition When I did $cat /sys/class/net/eth0/carrier, I can see message "/sys/class/net/eth0/carrier OPEN."
I think that when driver modifys /sys/class/net/eth0/carrier, inotifywait can't notice modifing.
Thank you!
