Observer ishahak
How to access AXI registers under Petalinux?
I'm a software guy, working on Zynq UltraZed + IOCC board from Avnet.
I got a hardware declaration (HDF) file from an FPGA developer, and created a petalinux project using the following technique:
  • First, I've put the HDF file into a folder called "hdf". I unzipped the '.bit' file out of it into the same folder, because for some reason it was necessary.
  • Then I did the following:
cd <place for project>
petalinux-create --type project --template zynqMP --name <petalinux-proj>
cd <petalinux-proj>
mkdir hw_platform
cp <my-hdf-folder>/*.hdf hw_platform/uz_petalinux_hw.hdf
cp <my-hdf-folder>/*.bit hw_platform/system_wrapper.bit
petalinux-config --oldconfig --get-hw-description=./hw_platform
petalinux-build
petalinux-package --boot --fsbl images/linux/zynqmp_fsbl.elf --fpga hw_platform/system_wrapper.bit --uboot --force
After that, I've got BOOT.BIN and image.ub to put into the SD card, and rootfs.cpio file as the rootfs, which I was setting as NFS mount.
My plnx-aarch64-system.dts shows these lines:
   amba_pl@0 {
      #address-cells = <0x2>;
      #size-cells = <0x2>;
      compatible = "simple-bus";
      ranges;
      axi2regs@80002000 {
         compatible = "xlnx,axi2regs-1.1";
         reg = <0x0 0x80002000 0x0 0x1000>;
         xlnx,s00-axi-addr-width = <0xb>;
         xlnx,s00-axi-data-width = <0x20>;
I was trying to use the python script described here to read the registers at 0x80002000, but these addresses seem to be non  accessible through /dev/mem.
Under my petalinux project folder, I see the following structure:
tree ./project-spec/hw-description/drivers
└── axi2regs_v1_0
    ├── data
    │   ├── axi2regs.mdd
    │   └── axi2regs.tcl
    └── src
        ├── axi2regs.c
        ├── axi2regs.h
        ├── axi2regs_selftest.c
        └── Makefile
The header file contains this:
* C-style signature:
* u32 AXI2REGS_mReadReg(u32 BaseAddress, unsigned RegOffset)
Questions:
  1. Does it mean that my linux build contains a driver for accessing the registers? Is there a way to verify that by looking under /sys/class?
  2. Is it possible to use something similar to /dev/mem to access the AXI registers?
  3. In the Vivado SDK, if I create an application project of type Linux, how can I setup the project to allow me to use the AXI2REGS_mReadReg API? I didn't find any clear tutorial for doing that.
I'll be very thankful for getting some answer...
Tags (3)
Observer ishahak
Re: How to access AXI registers under Petalinux?
Well it took me two weeks to find the solution:
Had to add clk_ignore_unused to the bootargs variable...
Without that, accessing the memory of the AXI was causing the machine to hang up, trying to read an answer from a non-clocked device.
I'll add that it is possible to use the /dev/mem and mmap, but it is better to use the generic-uio driver, as it is safer and accessible to non-root users.
To do that:
Find system-user.dtsi and add the following to its end, making sure to put the name for your own IP:
&axi2regs_0 {
   compatible = "generic-uio";
Also add your bootargs variable with this: uio_pdrv_genirq.of_id="generic-uio"
And also do "petalinux-config -c kernel" and go to "device drivers">"Userspace...", and there turn "Userspace io platform" into "*" by pressing "y".
So now you should have the generic-uio driver active and connected to your IP. To verify that, look under /sys/class/uio/uio0/maps/map0.
You can then install uioctl by Bryan Newbold and test the registers, for example you can read the first register using
./uioctl /dev/uio0 0x0
(to compile the uioctl tool, use the cross compiler found in your petalinux installation, e.g.
/opt/plnx/tools/linux-i386/aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc)
And BTW, do not expect the memory addresses of AXI registers to appear under /proc/iomem, as it is not there.
So I've put here some of the many things that I have learned while struggling to get my board talking to me :)
-Itay
Tags (3)
Scholar vanmierlo
As suggested by the thread you mentioned, first try to verify with U-boot that you can access the registers (using md) without an OS.
Then try devmem on the linux command line.
There is no known linux kernel driver compatible with "xlnx,axi2regs-1.1".
Observer ishahak
Hi @vanmierlo,
Thank you so much for taking the time to respond!
Indeed, 'md 0x80002000' reads the registers correctly, allowing me to see the expected data.
However, devmem in Linux is failing, probably due to inaccessible memory:
# devmem 0x80002000
[   49.832660] INFO: rcu_sched detected stalls on CPUs/tasks:
[   49.838058]  2-...: (0 ticks this GP) idle=98d/140000000000000/0 softirq=449/449 fqs=2626
Of course, there is no generic 'xlmx,axi2regs-1.1' driver. But isn't the above mentioned content of './project-spec/hw-description/drivers' mean that a driver was generated automatically for it?
Is it possible to manually edit the 'compatible' line, and put there a name of a generic linux driver?
I'll appreciate some help please.
Observer ishahak
To do that:
&axi2regs_0 {
-Itay
Tags (3)
