peterjohn
How to access USB flash drive on ZedBoard
I am working on a ZedBoard project in which I need to store the processed data on the USB flash drive connected to ZedBoard. I am looking for what is the default mode of the USB OTG. How to configure the ZYNQ as USB Host. Can anyone share the PetaLinux commands to read/write data to USB flash drive connected to ZedBoard ?
rfs613
USB host mode typically works out-of-the-box. All you need to do is mount the flash drive. An example might be:
mount /dev/sda1 /mnt
The exact device name (sda) and partition number (1) may differ for you. To find out, plug the USB flash drive in, and watch the serial console. Some messages should appear, indicating a new drive was found, and its partitions (if any).
The mount process can also happen automatically, whenever a USB drive is connected. To check if this is the case, run the command "mount" to show all active mounts, check if the USB drive is listed there.
Once you know where it is mounted, eg "/mnt" in my example above, you can just copy files to/from this directory (and subdirectories of course).
rfs613
