Visitor yelang1124
How to achieve the SD card detection? and i can‘t see the code where use the xlnx,has-cd = <0x1>; at kernel source code
for sd card detection , from  linux-kernel/Documentation/devicetree/bindings/mmc/mmc.txt  , i see the cd-gpios and wp-gpios can setting the gpio to use card-detect .  but for zedboard devicetree i can't find this, only see xlnx,has-cd = <0x1>; then i grep "xlnx,has-cd" at linux-kerbnel source code , i get noting no code use this,why?
my question is:
1、for zedboard sch , i can see sd-cd pin is mio47 , why i can't find cd-gpios = <&gpio0 47 0> in the zedboard dt.
2、what's mean xlnx,has-cd = <0x1>;  , Where's the code for using this?
thanks very much for reply.
Re: How to achieve the SD card detection? and i can‘t see the code where use the xlnx,has-cd = <0x1>; at kernel source code
Hi @yelang1124,
You are looking for to detect the SD card before or after the kernel boot?
If before, just follow the tutorial about how to build a Linux system on the wiki page (link
Kind Regards,
Florent
Florent
