Lordlothard
How to add Driver library to existing rootfs for VITIS development in OSL flow
I am working with an UltraScale + MPSoC  on an ultra96V2 avnet dev board.
I Built a custom Kernel and device-tree using the tutorial "Linux OSL flow " , but i use an existing system file rootfs from the avnet's 2019.2 BSP.
The difference is that i have an AXI DMA IP in the PL for Hardware Acceleration. My device tree is good and I detect the axi_dma when i boot linux :
[    4.330334] xilinx-vdma a0000000.dma: Xilinx AXI DMA Engine Driver Probed!!
root@ultra96v2-oob-2019-2:/sys/class/dma# ls -l
total 0
lrwxrwxrwx 1 root root 0 Jan  1  1970 dma1chan0 -> ../../devices/platform/amba_pl@0/a0000000.dma/dma/dma1chan0
Now I'd like to develop my application on VITIS. The Driver pages advice to use the Driver APIs but the xilinx_dma library and dmaengine.h  is missing in my filesystem, and i don't really understand how to use it. Here are my interogations :
- What is the good way to have the libraries available when developing the app ?
- Do I need to add the library in the system file rootfs  ?
Also, for some reasons related to the company i work with i can't use petalinux or yocto to build the file system (for now).
I hope it can also help users developping their environment from scratch.
Have a good day !
Gautier
Lordlothard
Hi Shabbir,
Thank you for your reply !
Actually after some research I found that xilinx_dma library is a Linux Kernel Module and cannot be used "as is " from the kernel user space !
So it makes no sense to add it to the Root system File rootfs ...
What I think I need is a client like the DMA Proxy Design : Linux DMA From User Space - Xilinx Wiki - Confluence (atlassian.net)
And then following your advice I just need to include it like a library in VITIS , build the binary and paste it in the rootfs or executing it via the TCF agent debugger in VITIS !
However  this is the node to add in the Device-Tree :
  dma_proxy {
     compatible ="xlnx,dma_proxy";
     dmas = <&axi_dma_0 0
             &axi_dma_0 1>;
     dma-names = "dma_proxy_tx", "dma_proxy_rx";
 Where does the small dma client node go in the device tree ?
Thank you for your time,
Gautier
shabbirk
Hi Gautier,
One way is to build the application outside the tool flow and get the binary into the rootfs.
Shabbir
Lordlothard
Hi Shabbir,
  dma_proxy {
             &axi_dma_0 1>;
Gautier
zebill
Hi Gautier, As I am trying to use the same piece of code, I can reply to this question!
I put this piece of code in the "system-user.dtsi" file located in the "meta-user/recipes-bsp/device-tree/files" directory, by the way, as this node is new, it has to be inserted in the heading section. The snippet below is extracted from my file:
/include/ "system-conf.dtsi"
	chosen {
		bootargs = "earlycon clk_ignore_unused uio_pdrv_genirq.of_id=generic-uio";
		stdout-path = "serial0:115200n8";
	/* Test to use AXI DMA ...*/
	dma_proxy {
		dmas = <&axi_dma 0  &axi_dma 1>;
Hope this helps!
Guilhem
Lordlothard
Thank you Guilhem for your answer !
I added  another dma in my design along with the one in loopback for the axi_dma test module.
I started my linux with the new Device -Tree and it seems to work :
root@ultra96v2-2020-1:~# cd /sys/class/dma
root@ultra96v2-2020-1:/sys/class/dma# ls -l
lrwxrwxrwx 1 root root 0 Jan  1  1970 dma1chan1 -> ../../devices/platform/amba_pl@0/a0000000.dma/dma/dma1chan1
lrwxrwxrwx 1 root root 0 Jan  1  1970 dma2chan0 -> ../../devices/platform/amba_pl@0/a0010000.dma/dma/dma2chan0
lrwxrwxrwx 1 root root 0 Jan  1  1970 dma2chan1 -> ../../devices/platform/amba_pl@0/a0010000.dma/dma/dma2chan1
root@ultra96v2-2020-1:/sys/devices/platform# ls -l
total 0
drwxr-xr-x  5 root root    0 Jan  1  1970 amba_pl@0
drwxr-xr-x  3 root root    0 Jan  1  1970 axidmatest@1
drwxr-xr-x  3 root root    0 Jan  1  1970 dma_proxy
 I did not took the time to test it, but it's another subject.
Yours faithfully,
Gautier.
