06-21-2020 09:47 PM - edited 06-21-2020 09:48 PM
I can build the test.c without using yocto in my terminal easily. So this means
there is no problem with the test.c or the libcurl in my host machine.
However, when I build using yocto it complains that it cannot find curl/curl.h.
DEBUG: Executing shell function do_compile
| test.c:5:10: fatal error: curl/curl.h: No such file or directory
| #include <curl/curl.h>
| compilation terminated.
| WARNING: exit code 1 from a shell command.
Here is my directory structure which contains my example based out of libcurl.
├── curlTest
│ ├── curlTest
│ │ ├── README.txt
│ │ └── test.c
│ └── curlTest.bb
Here is my curlTest.bb
curlTest.bb
SUMMARY = "Simple Hello World Application"
DESCRIPTION = "A test application to demonstrate how to create a recipe \
by directly compiling C files with BitBake."
SECTION = "examples"
PRIORITY = "optional"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "\
file://README.txt;md5=321180101a13e8916e6753497a4f9c82"
SRC_URI = "file://test.c \
file://README.txt"
S = "${WORKDIR}"
do_compile() {
${CC} ${CFLAGS} ${LDFLAGS} -o testCurl test.c -lcurl
do_install() {
install -d ${D}${bindir}
install -m 0755 hello ${D}${bindir}
Here is the example of libcurl based out of the libcurl website.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
struct MemoryStruct {
char *memory;
size_t size;
static size_t
WriteMemoryCallback(void *contents, size_t size, size_t nmemb, void *userp)
size_t realsize = size * nmemb;
struct MemoryStruct *mem = (struct MemoryStruct *)userp;
char *ptr = realloc(mem->memory, mem->size + realsize + 1);
if(ptr == NULL) {
/* out of memory! */
printf("not enough memory (realloc returned NULL)\n");
return 0;
mem->memory = ptr;
memcpy(&(mem->memory[mem->size]), contents, realsize);
mem->size += realsize;
mem->memory[mem->size] = 0;
return realsize;
int main(void)
CURL *curl_handle;
CURLcode res;
struct MemoryStruct chunk;
chunk.memory = malloc(1); /* will be grown as needed by the realloc above */
chunk.size = 0; /* no data at this point */
curl_global_init(CURL_GLOBAL_ALL);
/* init the curl session */
curl_handle = curl_easy_init();
/* specify URL to get */
curl_easy_setopt(curl_handle, CURLOPT_URL, "https://www.example.com/");
/* send all data to this function */
curl_easy_setopt(curl_handle, CURLOPT_WRITEFUNCTION, WriteMemoryCallback);
/* we pass our 'chunk' struct to the callback function */
curl_easy_setopt(curl_handle, CURLOPT_WRITEDATA, (void *)&chunk);
/* some servers don't like requests that are made without a user-agent
field, so we provide one */
curl_easy_setopt(curl_handle, CURLOPT_USERAGENT, "libcurl-agent/1.0");
/* get it! */
res = curl_easy_perform(curl_handle);
/* check for errors */
if(res != CURLE_OK) {
fprintf(stderr, "curl_easy_perform() failed: %s\n",
curl_easy_strerror(res));
else {
* Now, our chunk.memory points to a memory block that is chunk.size
* bytes big and contains the remote file.
* Do something nice with it!
printf("%lu bytes retrieved\n", (unsigned long)chunk.size);
/* cleanup curl stuff */
curl_easy_cleanup(curl_handle);
free(chunk.memory);
/* we're done with libcurl, so clean it up */
curl_global_cleanup();
return 0;
06-28-2020 11:08 AM - edited 06-28-2020 11:09 AM
Hi @joshis1 ,
Here is the example.
$ petalinux-create -t apps -n curltest --template c --enable $ tree project-spec/meta-user/recipes-apps/curltest/ project-spec/meta-user/recipes-apps/curltest/ ├── curltest.bb ├── files │ ├── curltest.c │ └── Makefile └── README 1 directory, 4 files
/* <DESC> * Very simple HTTP GET * </DESC> */ #include <stdio.h> #include <curl/curl.h> int main(void) { CURL *curl; CURLcode res; curl = curl_easy_init(); if(curl) { curl_easy_setopt(curl, CURLOPT_URL, "https://example.com"); /* example.com is redirected, so we tell libcurl to follow redirection */ curl_easy_setopt(curl, CURLOPT_FOLLOWLOCATION, 1L); /* Perform the request, res will get the return code */ res = curl_easy_perform(curl); /* Check for errors */ if(res != CURLE_OK) fprintf(stderr, "curl_easy_perform() failed: %s\n", curl_easy_strerror(res)); /* always cleanup */ curl_easy_cleanup(curl); } return 0; }
# # This file is the curltest recipe. # SUMMARY = "Simple curltest application" SECTION = "PETALINUX/apps" LICENSE = "MIT" LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302" SRC_URI = " \ file://curltest.c \ file://Makefile \ " S = "${WORKDIR}" DEPENDS += " \ curl \ openssl \ " CFLAGS += "-c -g" LDFLAGS += "-lpthread -lcurl -lssl" EXTRA_OEMAKE = "'CFLAGS=${CFLAGS}' 'LDFLAGS=${LDFLAGS}'" do_compile() { oe_runmake } do_install() { install -d ${D}${bindir} install -m 0755 curltest ${D}${bindir} }
$ petalinux-build -c curltest
06-28-2020 04:37 AM
Hi @joshis1 ,
You are using a Yocto or a petalinux? if you are using petalinux please refer to a UG1144.
With Regards,
Shubhamgi
Hi @joshis1 ,
08-11-2020 04:27 AM
Dear sandeepg:
I encountered a similar problem, i can understand your example code,
but my issue is that, how to enable the curl library in petlinux project or add the open curl source firstly ?
after i follow your example steps, i can not build successfully, the log as follow:
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Loading cache: 100% |#########################################################################################################################################################| Time: 0:00:00
Loaded 3262 entries from dependency cache.
Parsing recipes: 100% |#######################################################################################################################################################| Time: 0:00:01
Parsing of 2472 .bb files complete (2439 cached, 33 parsed). 3265 targets, 226 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |####################################################################################################################################################| Time: 0:00:06
Checking sstate mirror object availability: 100% |############################################################################################################################| Time: 0:00:17
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: curltest-1.0-r0 do_compile: oe_runmake failed
ERROR: curltest-1.0-r0 do_compile: Function failed: do_compile (log file is located at /home/alinx/work/trunk/demo_prj/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/curltest/1.0-r0/temp/log.do_compile.18545)
ERROR: Logfile of failure stored in: /home/alinx/work/trunk/demo_prj/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/curltest/1.0-r0/temp/log.do_compile.18545
Log data follows:
| NOTE: make -j 8 CFLAGS= -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/alinx/work/trunk/demo_prj/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/curltest/1.0-r0=/usr/src/debug/curltest/1.0-r0 -fdebug-prefix-map=/home/alinx/work/trunk/demo_prj/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/alinx/work/trunk/demo_prj/build/tmp/sysroots/plnx_arm= -c -g LDFLAGS=-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -lpthread -lcurl -lssl
| ERROR: oe_runmake failed
| arm-xilinx-linux-gnueabi-gcc -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a9 --sysroot=/home/alinx/work/trunk/demo_prj/build/tmp/sysroots/plnx_arm -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -lpthread -lcurl -lssl -o curltest curltest.o
| curltest.o: In function `main':
| /usr/src/debug/curltest/1.0-r0/curltest.c:45: undefined reference to `curl_easy_init'
| /usr/src/debug/curltest/1.0-r0/curltest.c:47: undefined reference to `curl_easy_setopt'
| /usr/src/debug/curltest/1.0-r0/curltest.c:49: undefined reference to `curl_easy_setopt'
| /usr/src/debug/curltest/1.0-r0/curltest.c:52: undefined reference to `curl_easy_perform'
| /usr/src/debug/curltest/1.0-r0/curltest.c:64: undefined reference to `curl_easy_cleanup'
| /usr/src/debug/curltest/1.0-r0/curltest.c:56: undefined reference to `curl_easy_strerror'
| collect2: error: ld returned 1 exit status
| make: *** [Makefile:11: curltest] Error 1
| ERROR: Function failed: do_compile (log file is located at /home/alinx/work/trunk/demo_prj/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/curltest/1.0-r0/temp/log.do_compile.18545)
ERROR: Task (/home/alinx/work/trunk/demo_prj/project-spec/meta-user/recipes-apps/curltest/curltest.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2325 tasks of which 2320 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
