dm.pogrebnoy
How to boot Linux (U-BOOT, GMII2RGMII and TFTP)?
Hi!
My custom board consist two Ethernets MACs connected thru EMIO by means of GMII2RGMII cores. I succesfully run last linux kernel and both interfaces work smoothly.
Now I want to boot my board from TFTP server. But as I can see u-boot does't support configuration of GMII2RGMII core. I inspect zynq_gem.c u-boot driver for it and I can not find any mention about GMII2RGMII core.
But I also read documentation on ethernet driver in u-boot and found this line in it: This driver can be used with gmii2rgmii converter driver
I'm frustrating a little about this now. Should I find a solution in existed driver, or may be I need to patch it to have needed functionality?
Tags (3)
dm.pogrebnoy
I already found a solution, by patching zynq_gem.c ethernet driver in u-boot.
In function static int zynq_gem_init(struct udevice *dev) I insert code that shown below:
	switch (priv->phydev->speed) {
		case SPEED_10: {
			priv->bus->write(priv->bus, 8, 8, 0x10, 0x0100);
			printf("Gmii2Rgmii adapter configuration 10 Mb/s done!\n");
		break;
		case SPEED_100: {
			priv->bus->write(priv->bus, 8, 8, 0x10, 0x2000);
			printf("Gmii2Rgmii adapter configuration 100 Mb/s done!\n");
		break;
		case SPEED_1000: {
			priv->bus->write(priv->bus, 8, 8, 0x10, 0x0040);
			printf("Gmii2Rgmii adapter configuration 1000 Mb/s done!\n");
		break;
i.e. configure GMII2GRMII adapter manually. May be too dirty, but it works. Finally I can boot from TFTP server. Anybody know a better solution?
aravindb
Hi @dm.pogrebnoy
Not verified tftp boot with your similar design, but in general below are the steps.
Run below commands in u-boot console:
1.dhcp
2.setenv serverip <HOST IP ADDR>
3.run netboot;
You can setup the tftp server  in host side using below steps.
1. sudo apt-get install xinetd tftpd tftpd
2. sudo vim /etc/xinetd.d/tftp
3.Add the following structute in /etc/xinetd.d/tftp file if it not there or edit if it exists.
service tftp
protocol = udp
port = 69
socket_type = dgram
wait = yes
user = nobody
server = /usr/sbin/in.tftpd
server_args = /tftpboot
disable = no
4. sudo service xinetd restart
Testing tftp sever:
1. cp <file > /tftpboot
2. sudo chmod 777 /tftpboot
3.tftp localhost
4. get <filename>
If the file received successfully without any error from the tftpserver then tftp service is configured correctly.
 Thanks & regards
Aravind
dm.pogrebnoy
		case SPEED_10: {
		break;
		case SPEED_100: {
		break;
		case SPEED_1000: {
		break;
aravindb
HI @dm.pogrebnoy
Thanks for sharing the solution.
Thanks & regards
Aravind
gsatish10
Basically Ethernet boot support from u-boot :
1st Part:
Adding Ethernet controller Mux pins in one function
Call the same function using structure
Add ethernet controller register values in "Include " directory
2nd Part:
u-boot intilization code looks for set of I/O devices at the time of boot_init_r which will initilizes serial console, uart console & Ethernet console  (If so, it will call Mux pins structure and Mac controller register definitions from include directory)
Based on the above procedure, you are adding  the corrspending Mac controller Speed which will be one of configuration to make the PHY controller up and start transmitting packets, so the procedure followed by you is right.
If still have doubts, look for "Ethernet Porting on U-boot " , will giuve the same procedure
Thanks & Regards
Satish G
G Satish Kumar
abcdefjxz
Sorry to disturb.
Now I have the same problem about gmii2rgmii core. May I ask some questions about uboot if convenient.
