How to boot the Z7000 with the ubuntu?
I have follow the step in http://www.wiki.xilinx.com/Ubuntu+on+Zynq
The SD info is
:~$ sudo fdisk -l /dev/sdb
Disk /dev/sdb: 3986 MB, 3986685952 bytes
123 heads, 62 sectors/track, 1021 cylinders, total 7786496 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Disk /dev/sdb doesn't contain a valid partition table
255 heads, 63 sectors/track, 484 cylinders, total 7786496 sectors
Disk identifier: 0xe2c99ac5
Device Boot Start End Blocks Id System
/dev/sdb1 * 2048 411647 204800 c W95 FAT32 (LBA)
/dev/sdb2 411648 7786495 3687424 83 Linux
$ ls -l /mnt/boot
total 6582
-rwxr-xr-x 1 root root 348480 May 25 10:21 boot.bin
-rwxr-xr-x 1 root root 6378 May 25 10:21 devicetree.dtb
-rwxr-xr-x 1 root root 2996704 May 25 10:21 uImage
-rwxr-xr-x 1 root root 3387520 May 25 10:21 uramdisk.image.gz
$ ls -l /mnt/root
total 92
drwxr-xr-x 2 root root 4096 May 25 10:22 bin
drwxr-xr-x 2 root root 4096 May 25 10:22 boot
drwxr-xr-x 6 root root 4096 May 25 10:22 dev
drwxr-xr-x 57 root root 4096 May 25 10:22 etc
drwxr-xr-x 3 root root 4096 May 25 10:22 home
drwxr-xr-x 11 root root 4096 May 25 10:22 lib
drwx------ 2 root root 16384 May 25 10:15 lost+found
drwxr-xr-x 2 root root 4096 May 25 10:22 media
drwxr-xr-x 2 root root 4096 May 25 10:22 mnt
drwxr-xr-x 2 root root 4096 May 25 10:22 opt
drwxr-xr-x 2 root root 4096 May 25 10:22 proc
drwx------ 5 root root 4096 May 25 10:22 root
drwxr-xr-x 6 root root 4096 May 25 10:22 run
drwxr-xr-x 2 root root 4096 May 25 10:22 sbin
drwxr-xr-x 2 root root 4096 May 25 10:22 selinux
drwxr-xr-x 2 root root 4096 May 25 10:22 srv
drwxr-xr-x 2 root root 4096 May 25 10:22 sys
drwxr-xr-x 2 root root 4096 May 25 10:22 tmp
drwxr-xr-x 10 root root 4096 May 25 10:22 usr
drwxr-xr-x 11 root root 4096 May 25 10:23 var
But the board could not boot.
