Newbie lgoss00
How to boot uboot from SD Card on ZCU102 Rev 1.1 board
I just received a new ZCU102 board that's marked Revision 1.1.  I can not boot uboot from the SD card.
- I only see: "!! Press ESC to enter System Controller mode." on my serial port, then nothing.
- I found SW6 settings for rev 1.0 and rev D board.  But not rev 1.1.  What are they?
- Is there a working pre-built boot.bin available for download for this rev that I can try?
Scholar austin
Re: How to boot uboot from SD Card on ZCU102 Rev 1.1 board
All production zcu102 boards should be:
SW6[4:1]: off,off,off, on  to boot from SD card.
Images abound, like this one for the reVision Base TRD:
http://www.wiki.xilinx.com/reVISION+Getting+Started+Guide+2017.2
(in the instructions on unzipping files)
Austin Lesea
Principal Engineer
Xilinx San Jose
Newbie lgoss00
Thanks.  It turns out that it was booting ok, but I was getting no output over the serial uart.  I was using a Mac, and apparently the latest silabs usb/serial driver for Mac OS does not work with this board.  Switched to a Win7 machine and version 6.7.5 driver, and it's working.
